Old 04-12-2012, 12:46 PM   #1
Bdave
My Ride: M3 HPF Stage 3
Second tank draining?
Chris was posting on bimmerforums some info on damaged motors. This one looked like user error. Could someone explain what happened? What "second" tank? A fuel cell? I dont understand.
George
* Product: HPF Stage 2
* Problem: April 2010 - Engine Failure
* Diagnosis: Car in Beirut Lebanon. Appears that car may have been set to race mode with residual pump gas in 2nd tank.
* Customer Service: Customer upgraded to stage 3 at substantial discount.
* Product Change: Posted on forums that draining gas from tank will not drain 2nd tank. Customer must drive car until mileage left says zero. Customer must add a minimum of 10 gallons of 110 leaded before flipping race fuel switch.
* Link: None
http://forums.bimmerforums.com/forum....php?t=1610423
Bdave is offline   Reply With Quote
Old 04-12-2012, 01:15 PM   #2
///3ME
My Ride: Z/71
I would imagine he is talking about the siphon side of the saddle tank.
///3ME is offline   Reply With Quote
Old 04-12-2012, 01:54 PM   #3
Bdave
AHh. There is a hidden portion to our fuel tanks? Very interesting. All this time and I was unaware of this. I donbt know how I missed never hearing about it.
So how DO you pump an OEM tank dry? Let me see if I can find some links on this.
EDIT: OK I found a schematic for my fuel tank. I can see that to properly pump the tank DRY, BOTH right and left sending unit access ports must be opened. The one side contains the fuel pump and the other is just a sending unit, but they both will give you the access you need to use something like this:
http://www.amazon.com/Flo-08338-MaxF..._bxgy_sg_img_b
two gallons per minute flow. Perfect.
This saddle shape has to be what he meant by the "second tank". I am glad I know now. This might save some other people a lot of errors when you THINK you have pumped a tank dry and you still have a 1/4 tank sitting on the left side!
Thank you 3ME for sending me in the right direction. I had to say I kept thinking it was something else.
Old 04-12-2012, 06:19 PM   #4
///3ME
My Ride: Z/71
You are welcome BDave. Looking forward to seeing your unique system in action.
Old 04-12-2012, 06:28 PM   #5
Bdave
My fuel cell? Thats not unique. It is a painfully simplified version of what Neslon Engineering did in this case. They had a fuel cell that would start pumping on demand when high boost condition took place...all governed by owners foot. It is an ultra complex system that is all automatic. Looked like it was prone to issues so I made everything manual. Stop, open the hood and switch. Still, only 20 seconds, but nothing to fail.
You have to watch this video, however. This guy is insane, the owner and the builder!
