Old 04-13-2012, 09:53 PM   #1
hernanz
My Ride: 325i Sedan
1998 528i wont start
Hi Everyone,
I need help to troobleshot my 98 528i, I changed the sparkplugs and now it wont start, I change the plugs back to the hold ones and still wont start!!
not sure what the problem was!
please help! Thanks
hernanz is offline   Reply With Quote
Old 04-13-2012, 09:57 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Make sure you connected all the grounds...and make sure you have the coils firmly attached...until you hear a dull click.
If you did nothing other than the plugs...I suspect you simply forgot to connect one of the grounds...front back or middle.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 04-13-2012, 10:09 PM   #3
hernanz
My Ride: 325i Sedan
Thanks for the hint! do you have a picture of the Grounds im really newby on this! :S
Old 04-14-2012, 06:44 AM   #4
dmax
dmax's Avatar
There are three you removed when doing the plugs...at the 1st and 6th cylinder and one between 3 and 4 iirc.
While you're there, like I said, make sure the boots are firmly attached to the plugs. If you have a weird feeling you disconnected something else, check that too. So for instance, if you disconnected the cable going the the + terminal under the hood, make sure that's back on tight.
Other than that, you shouldn't have been anywhere else that I know of. But, given this was your first time, I don't know what all you might have done.
Oh, I wonder if maybe you managed to put those tiny ground straps at 1 and 6 below not above that 'brass H' spacer/connector? The H's connection all the coils together. Maybe you forgot one of the little 8 mm nuts on top of the grounds?
HTH
Mangofy your E46!
