Old 04-14-2012, 11:25 AM   #1
Steven747
My Ride: 05 330ci
Symptoms of a Bad Battery. But not ! Help!
hey fanatics.
my car has been acting weird yesterday and today.
last night while driving home and playing music my odometer reset and the music stopped and started again real quick while driving but car did not turn off or anything.
last night when i got home unloading things out of my car i went to press the door open button in the center console and it wouldn't work and i realized all power to the car was lost car wouldn't crank, nothing, symptoms of a unhooked battery cable. i went to the trunk checked positive and negative and everything was snug tite. walk back around and my cabin lights are on and i go to start it and the car starts up normal normal.
this morning after going and getting some coffee back in my car sipping i go to start the car and nothing. again i went to the trunk and everything is snug. is there a glitch or what part of the car would cause it to loose all power everything in the car then allow it to start right back up 40 seconds later?
alternator?
battery?
this isn't a ignition issue or spark plug related because like i said all power.
next step for me is have a gas station check how much juice is in the battery.
any suggestions? anyone run into this before?
tia
Old 04-14-2012, 11:36 AM   #2
Brinkley
My Ride: 99 328i, 07 z4 3.0
Definitely sounds like bad connections as I've run into that before myself. I kinda doubt it's alternator if one minute car is completely dead next all good when not running. Probably battery related one way or another , battery/connection/battery cable.
Brinkley is offline   Reply With Quote
Old 04-14-2012, 11:46 AM   #3
Steven747
My Ride: 05 330ci
i appreciate the quick response.
so what cable/connections do you recommend i look at?
Old 04-14-2012, 11:49 AM   #4
Brinkley
check the other end of the negative cable where it grounds and make sure that's good, then check that the power cable is good and secured to the post clamps. Are the clamps in good shape, not corroded?
Old 04-14-2012, 12:05 PM   #5
Steven747
My Ride: 05 330ci
they all look good i just tightened down the negative again to make sure its on securely and will update thread if the issue persists .
thanks brinkley. i did see a little bit of corrosion on a clamp.
Old 04-14-2012, 12:22 PM   #6
Brinkley
Could be that. Might be worth taking battery into autozone for check as well.
Old 04-14-2012, 12:24 PM   #7
sr71blackbird92
My Ride: 2004 325i - 2002 M3
I had similar issues, its certainly a connection issue.
From experience, id say check the condition of your ground wire between the battery and the rear frame - especially where it actually connects to the frame. that wire can get bent and not conduct as well as it used to.
02 M3: 19" OEM Wheels - OEM CSL Bumper - OEM CSL Steering Wheel - Headers - Angel Eyes - Carbon Fiber Interior Wrap - Smoked Corners - Powerflex Bushings All Around - New Vanos - New Clutch
05 545i Daily Driver - Space Gray Metallic with the Sport Package
2004 325i Sport - Sold | 1997 E39 540i6 - Sold
sr71blackbird92 is offline   Reply With Quote
Old 04-14-2012, 12:35 PM   #8
Brinkley
thread jack: love the picture in your sig!
Old 04-14-2012, 02:30 PM   #9
Steven747
My Ride: 05 330ci
will do brinkley and blackbird i will do some research.
and brinkley who's sig?
