Sponsored by BimmerWorld
Old 04-15-2012, 01:41 PM   #1
pawelgawel
My Ride: 330CI
Bilstein PSS10 instructions help
Hi guys,
I picked up a used set of PSS10s and I have couple of questions....
1. Im not sure how many rings should I have on the rear threaded sleeve. I have two up front which makes sense for them not to move, but in the rear there is only one.... I found an old thread but it didn't clerify if I should have one or two. the PSS9 has two so I don't know right now.
2. the rear adjustment sleeve should be located on the top or bottom of the spring when seated?
3. with dampaning adjustment... what is the best way to readjusting it without damaging the # on the adjuster?
4. on the photo in the Turner site, the rear shocks have washers on top wich I don't have... can i just follow the OE specs and use those in stead or do I need to use specific ones? and finally..
5. from my understanding the pss10 kit lowers the car 1" on its highest setting. meaning it cant get any higher then that. I like a slight drop from my sport syspension. what is the amount I should set it at in hight, Ill probably use 1 for dampening??
And I know Im probably a retard for asking these questions. Im a coilover vergin... slightly scared
here they are... cant tell how many rings on the rear spring hub:
http://www.turnermotorsport.com/p-15...328i-330i.aspx
so in this pic, i can't tell if there are two rings in the rear sleeve and I don't know if I need to use specific washer for the rear shocks or will the OE be enough
pawelgawel is offline   Reply With Quote
Old 04-15-2012, 09:21 PM   #2
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Did you even think to go to Bilsteins' web site?
http://www.bilsteinus.com/products/p...pss9pss10.html
There is a lot of info there. It gets moved around, but manuals are there to be downloaded.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 04-15-2012, 09:43 PM   #3
pawelgawel
My Ride: 330CI
ya... got it. thank you !!
can someone let me know how much I should set the spring at in front and back for a nice drop of one finger gap on 17" stock ?
