Thread Tools Search this Thread Rating: Thread Rating: 49 votes, 5.00 average. Display Modes
Old 12-05-2012, 09:04 PM   #181
briangl92
My Ride: VQ37VHR
Originally Posted by gselsidi View Post
Was told today the car still didn't run good. The guy told me they replaced the camshaft under warranty. I'm not sure if he meant sensor or the actual camshaft lol. If they replaced the whole camshaft that would be pretty crazy. Will find out later tonight or tomorrow when I get the car, and try to find out what the culprit was to the rough idle. It seems it might have not been the vanos.
That'd be rare for a camshaft to go bad. The sensor is a common problem across all e46s.
Have they checked your intake hoses for cracks?
briangl92 is offline   Reply With Quote
Old 12-05-2012, 09:10 PM   #182
gselsidi
My Ride: 2005 325i M56
They replaced the whole camshaft in the notes it said vanos was stuck and it caused camshaft to move From original position it also mentioned something about one of the pistons not being able to move properly. Who knows maybe the tech messed it up removing the vanos, but the idle issues are fixed.
gselsidi is offline   Reply With Quote
Old 12-05-2012, 09:35 PM   #183
briangl92
My Ride: VQ37VHR
Wow. Well it's a good thing you took it in. Keep us updated!
Old 12-05-2012, 10:06 PM   #184
gselsidi
Going to take it back as the shifter selector light doesn't work and the dsc button seems to not work either.
Old 12-06-2012, 09:00 PM   #185
gselsidi
Quick question, if a part under warranty say for example the vanos breaks and causes damage to another part of the engine like a piston would warranty cover that also?
Old 12-07-2012, 01:06 AM   #186
briangl92
My Ride: VQ37VHR
Yikes, well if it wasn't like that before you brought it in they should be liable for sure.
I guess it would probably depend on the circumstances but in general, I'd say yes. But it all depends. Half the time we can't even get the stuff that's covered to get covered.
Old 12-10-2012, 03:54 PM   #187
gselsidi
Hey do you have a picture of our ABS module? where is it located on our cars? I want to test it by unplugging it. Also, what do you think about changing transmission fluid at 99k if its never been done before? on our cars? i have an 05 btw my mechanic was warning me not to do it.
Old 12-10-2012, 04:03 PM   #188
gselsidi
Also where is the abs module on this car is it under the intake? That's where I see those metal tube things going down too. I looked everywhere on top and I couldn't find it. Thanks
Old 12-11-2012, 11:10 AM   #189
briangl92
My Ride: VQ37VHR
Yes the thing with the metal tubes is the ABS pump. Its easier and better to test it through INPA.
Back when I was going to a mechanic (he was an ex-BMW and Mercedes tech with a PhD in mechanical engineering and used to rebuild transmissions - one of those old guru types), I was told that anything past 75k is a gamble. If you don't change it, the seals will harden and start letting fluid through. If you're past 75k and change it, it can kill your transmission too because the resoftening of seals can also let fluid through and wreck the transmission.
If it were me, I'd change it but do it gradually.
Old 12-21-2012, 04:58 PM   #190
chillinhardinanE46
My Ride: 2003 325i
will dealer charge for diagnosis of an M56? I have a P0430 code which related to post cat o2 sensor/ cats. Will they charge i i take it in? I have a slight rough idle.
chillinhardinanE46 is offline   Reply With Quote
Old 12-22-2012, 02:52 AM   #191
briangl92
My Ride: VQ37VHR
Yes, they'll charge a diagnostic fee. But if they find a problem that is covered, they waive the fee.
Old 12-22-2012, 07:27 PM   #192
gselsidi
Mine charges $150 and if you do the work with them which I don't they waive it or if it's covered under warranty. Go to dealer ratings and read reviews for good dealers. These guys around me have a very good reputation. A replacement key is only $150 cheaper then online websites.
Old 02-21-2013, 08:45 AM   #193
bimmerbeamer
My Ride: 03 325iT
California has a fairly extensive minimum emissions parts list that must be covered:
http://www.arb.ca.gov/msprog/aftermk...ad/proappb.pdf
I asked the dealer if the cylinder head was covered (as it's on the list). Their initial answer was no, but then they double checked and told me it was covered. I'm getting ignition coils, and the secondary air pump and hoses replaced under the warranty.
My car has about 110k and the fuel pump was working, but the dealer decided to replace the whole assembly since the tech found it was taking longer than normal for the car to start._nr_
bimmerbeamer is offline   Reply With Quote
Old 02-22-2013, 02:36 PM   #194
gselsidi
What was wrong with your cylinder head?
Old 02-22-2013, 04:17 PM   #195
Bear77
My Ride: '04 325iT SULEV
I just found out about the warranty thanks to this thread. It turns out, I just replaced my mass air sensor, air intake boot, and post-cat O2 sensors. Do I have any recourse to recoup my costs since these items were covered under warranty? I've also got a leaky VANOS oil line that I'm trying to get covered. BTW, I got the attached SULEV parts list from the service dep't at the local dealership.
Bear77 is offline   Reply With Quote
Old 02-22-2013, 04:46 PM   #196
gselsidi
What is this list? Things covered under warranty?
Old 02-22-2013, 04:48 PM   #197
Bear77
According to the service department at East Bay BMW, yes.
Old 02-22-2013, 04:51 PM   #198
gselsidi
Dude you are the man! !!!!! To bad I just replaced thermostat, they cover torque converter and so much other things I knew these things were covered as they all effect emissions.
Old 02-22-2013, 04:54 PM   #199
gselsidi
Hey also please see if you can get an 05 list if possible, but this is great.
Old 02-22-2013, 04:57 PM   #200
Bear77
Is there anyway to ge reimbursed from BMW NA for these repairs if we've already paid for them? Or are we S.O.L. for being ingorant?
m56, sulev
