Thread Tools Search this Thread Rating: Thread Rating: 49 votes, 5.00 average. Display Modes
Old 10-26-2013, 11:55 PM   #321
briangl92
My Ride: VQ37VHR
***The Official M56 SULEV Warranty Documents, Check-in, and Questions Thread***
Originally Posted by gselsidi View Post
Passenger towards the middle it was kinda in there, maybe your shields blocked it. Were these cars made in mexico? Along with the gas tank?
Ya, I'm not sure. Those were the only two lines I saw.
Lol mine was made in Munich, if I recall from the VIN.
Sent from my iPhone
briangl92 is offline   Reply With Quote
Old 10-30-2013, 05:49 PM   #322
Chaplian
My Ride: M56 SULEV
2003 325i here with 105k miles. Bought it with 100k miles, fuel pump went out at 104k. Replaced under warranty in Chicago, IL. I have a question, I was told that our M56s have different intakes, so I ordered the M56 upper-intake boot, and it was too short. I ordered a 325i boot made for the M54 now.
Chaplian is offline   Reply With Quote
Old 10-30-2013, 06:54 PM   #323
briangl92
My Ride: VQ37VHR
We do have different intakes, throttle bodies and different intake boots. A 325i M54 intake boot is too small in diameter and will not work. Our intake is the same diameter as the 330i. The intake boots have different (specific) part numbers, however.
I've replaced my upper and lower, and it may seem short, but it fits. Remember that the old one has stretched over time.
Sent from my iPhone
Old 10-31-2013, 02:30 PM   #324
Chaplian
My Ride: M56 SULEV
Alright, thanks. Had to stretch it a bit, but it did fit. Also, did you ever fix your stutter issue?
Old 10-31-2013, 03:15 PM   #325
briangl92
My Ride: VQ37VHR
It was my transmission going out, unfortunately.
Sent from my iPhone
Old 10-31-2013, 04:21 PM   #326
Chaplian
My Ride: M56 SULEV
Ouch. I need to change mine's fluid, I can't find a decent priced ZF in my area.
Old 10-31-2013, 06:36 PM   #327
briangl92
My Ride: VQ37VHR
When I ordered the stuff to change the fluid and filter in the new-to-me transmission, they accidentally shipped me two fill plugs and no drain plug. I was changing my tranny mount the other day and sure enough, it has a slow leak from old drain plug. Looks like I'll have to do a drain and fill with new plugs
Sent from my iPhone
Old 11-01-2013, 06:20 AM   #328
BimmerG
My Ride: 2004 325i SULEV
Sent from my iPhone
How many miles were on your old transmission?? I got 67K. Not sure if i should do the fluid....
BimmerG is offline   Reply With Quote
Old 11-01-2013, 06:15 PM   #329
Chaplian
My Ride: M56 SULEV
Do the fluid change, that's a great mileage to do it at.
Old 11-01-2013, 06:57 PM   #330
briangl92
My Ride: VQ37VHR
~95k miles. It had a fluid change at 75k. Not sure exactly why it went out.
This:
Old 11-06-2013, 06:35 PM   #331
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
would this be covered by the emissions warranty?
276D faulty tank ventilation valve
BMW OEM 13901433603 Vapor Canister Purge Solenoid
no SES or check engine lights. engine running rough with idle fluctuations. yesterday it stalled going 65mph on the freeway.
2004 325ci with 120k miles
itscoo2pyopants is offline   Reply With Quote
Old 11-06-2013, 07:41 PM   #332
briangl92
My Ride: VQ37VHR
It's emissions related so it should be. I'm surprised it didn't give a light along with the code.
Old 11-06-2013, 07:55 PM   #333
itscoo2pyopants
My Ride: E53 4.8is
yea no light. the car has just been running odd for the past few weeks. in the mornings it takes longer to start, and i have been noticing some idle fluctuations (not much maybe 600-700-800). just seems like the engine was running rough. i hooked it up to my INPA and found these codes with various frequency of occurrences:
CD8B local CAN communication error
27C3 oil level sensor
should i try to fix it myself? doesnt seem like it will be a lot of $$ in parts. im still not sure about the CD8B code, maybe that one will clear up on its own once the car is running efficiently again.
Old 11-06-2013, 08:23 PM   #334
briangl92
My Ride: VQ37VHR
The tank vent valve is in the tank, I believe. Which would mean that you'd be taking it in. Here's the diagram for the tank ventilation system, if you'd like to look it over:
http://realoem.com/bmw/showparts.do?...35&hg=16&fg=10
As far as the CAN error, I'm not too sure what's going on there. Just going off of the basis that it's a CAN error, it could be any number of things. You'd have to figure out if there's any further information that can be pulled from the CD8B to pinpoint where the communication break is occurring. Also, make sure that your DME is up to date with the most current software.
Oil level sensor would not be covered, although it's not a terrible repair.
Old 11-06-2013, 08:31 PM   #335
itscoo2pyopants
My Ride: E53 4.8is
I thought the fuel tank breather valve was located near the intake manifold?
Old 11-06-2013, 08:39 PM   #336
itscoo2pyopants
My Ride: E53 4.8is
http://bmwfans.info/parts-catalog/E4...breather_valve
Old 11-06-2013, 08:54 PM   #337
briangl92
My Ride: VQ37VHR
I'm honestly not sure if that's it or not. Even if it is, it's not a cheap part, unfortunately.
http://realoem.com/bmw/showparts.do?...=13&fg=15&hl=1
Old 11-07-2013, 04:57 AM   #338
itscoo2pyopants
My Ride: E53 4.8is
Played with the DIS and found some faults with the fuel pump. One code said "pump too low" the other said it wasn't working at all. Sporadic frequency. I think I'm going to have to take it in. Is the emissions warranty 10 years and 150k miles?
Old 11-07-2013, 09:50 AM   #339
briangl92
My Ride: VQ37VHR
15/150k.
You mentioned the car running rough. If the fuel pump was dead then I'd think it would be more than running rough.
Old 11-07-2013, 09:57 AM   #340
itscoo2pyopants
My Ride: E53 4.8is
It did stall and die on me the other day in the freeway. Maybe that fault was stored from that time
m56, sulev
