Sponsored by The Tire Rack
Old 04-16-2012, 01:26 PM   #1
Wickedly
My Ride: 2016 BSM ///M2
Smile fitting question - VMR
Hello,
Just got some VMR VB3's and they are 18x8.5 ET 40 front and 18x9.5 ET45 in the rear.
Currently have a 325i stock
looking for tires.
Please let me know which one of these 2 will be better.
I though of:
Front: 225/40ZR18 XL
Rear: 245/35ZR18 XL
But then I was told to get
Front: 235/40ZR18 XL
Rear: 255/35ZR18 XL
Is the second one more aggresive or what are the difference?
Thanks in advanced.
Wickedly is offline   Reply With Quote
Old 04-16-2012, 01:27 PM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
The wider ones will fit fine.
Do you ride a sportbike?
Old 04-16-2012, 01:49 PM   #3
Wickedly
wider ones meaning:
Rear: 255/35ZR18 XL
and which one will look better? as having a more aggresive look? or between them there is no much difference? just wide
Old 04-16-2012, 01:55 PM   #4
Snik
Snik's Avatar
yeah, those are the wider of the sets you listed.
They will look more aggressive as theyre wider and will fill the fenders better
Old 04-16-2012, 02:01 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
It may be hard to find 235 in certain brands so running 225 front and 255 rear would be fine also.
That's what I have.
Old 04-16-2012, 02:10 PM   #6
Wickedly
I found
Rear: 255/35ZR18 XL
in Michelin Pilot Super Sport (Max Performance Summer) for $1,018.00 in tirerack.com
Old 04-16-2012, 02:34 PM   #7
Wickedly
One last question,
If i go:
Rear: 255/35ZR18 XL
Will I need fender rolling or not?
Old 04-16-2012, 02:37 PM   #8
Riverbmr3
My Ride: MB E350 & BMW 325i
im running 235 front and 245 rear lowered with H&R sport cup kit wtih yoko s drive, tires affordable at tirerack, i rub a bit on 255 rear
Riverbmr3 is offline   Reply With Quote
Old 04-16-2012, 02:53 PM   #9
peytonracer4
:D
My Ride: '00 328i
Aren't 235 fronts a litter taller than oem though?
With the tire specs you posted on a stock suspension you shouldn't rub.
Old 04-16-2012, 03:03 PM   #10
Wickedly
Currently I have this 205/55R16 as a winter setup. Since I'm changing to a summer setup. I think that Front: 235/40ZR18 XL Rear: 255/35ZR18 XL will be fine . I won't be changing stock height for a while.
Old 04-16-2012, 03:28 PM   #11
BartenderPlease
My Ride: '03 540i/6 M-Sport
Do that ^
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 04-16-2012, 03:31 PM   #12
Snik
Snik's Avatar
What determines rubbing is wheel with and offset. Then that determines tire size.
Old 04-16-2012, 03:37 PM   #13
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
On stock suspension I can guarantee that you will have no rubbing issues running a 235/40/18 and 255/35/18 set up.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-16-2012, 03:42 PM   #14
Wickedly
Thank you all for you input, if someone has a pic of how it will look that be awesome !!
Old 04-16-2012, 03:50 PM   #15
Riverbmr3
im running exactly same wheel and offset with the OP
Old 04-16-2012, 04:02 PM   #16
Riverbmr3
For you OP
Old 04-16-2012, 04:04 PM   #17
Wickedly
Thanks a lot! now I know for sure what to get.
Old 04-16-2012, 06:23 PM   #18
Riverbmr3
