M3 diff carieer bearings causing play in shaft - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 04-17-2012, 03:58 AM   #1
abbas_m3
My Ride: bmw m3
Has this ever happened to anyone ? There is allot of play on the right axle shaft, I'm on the verge of buying a new diff. My mechanic told me the diff bearings are worn causing to much play. There is a clunk/vibration happening as I'm driving however when I accelerate ( hard) its gone.
Just want some information from other members to see if this has ever happened ?
abbas_m3 is offline   Reply With Quote
Old 04-19-2012, 08:30 PM   #2
RGuill96971
My Ride: 04 m3
one side will have more play then the other. its normal unless it has a bunch of play. driveline wind-up
RGuill96971 is offline   Reply With Quote
Old 04-20-2012, 02:53 AM   #3
abbas_m3
My Ride: bmw m3
My right side had allot more play, the diff started to wind when turning slow, there was a rear vibration started to happen. I changed the fluid and the whine and vibration did not go.
I already ordered a new diff, should be here next week hopefully
Old 04-22-2012, 01:02 PM   #4
RGuill96971
My Ride: 04 m3
wow, tell me if it fixes the whine?
Old 04-22-2012, 01:03 PM   #5
RGuill96971
My Ride: 04 m3
What is a lot?
Old 04-22-2012, 06:08 PM   #6
abbas_m3
My Ride: bmw m3
What is a lot?
Mechanic told me, quite allot more then the left hand side, and I wouldn't be able to give you an exact measurement but he said there was far to much play.
Old 04-22-2012, 06:09 PM   #7
abbas_m3
My Ride: bmw m3
Hopefully, the whine is from the diff. So a new diff should do the job
Old 04-22-2012, 09:07 PM   #8
RGuill96971
My Ride: 04 m3
Is this mechanic well versed in BMW's. Just the fact that its an M3 is a whole new world. Just hate to see you spend money and have the same problem.
Old 04-23-2012, 07:35 PM   #9
abbas_m3
My Ride: bmw m3
I guess he's pretty knowledgable, he's changed a few parts on my car and my brothers m3. And he tells me that he's changed a couple of doffs and works on m3s every now and then. If the diff ain't the problem then there are going to be some dramas
Old 04-29-2012, 07:44 PM   #10
mre
My Ride: too many to list
I am going through the same thing right now, I have the diff out to repair because of a loose right side axle. I am a Machininst/Engine builder by trade, so tackling a diff job is no problem for me. I pulled the half shafts expecting to see so worn stuff, but nothing is wrong. I do not llike the fact that it has play, but upon inspecting things, I think I know the reason. The spline is very close to the end. There is little to no area to support the thing. I am just going to replace the seals and go back with it. The ring and pinion look fantastic and there is absolutely no metal in the inside at all.
mre is offline   Reply With Quote
Old 04-29-2012, 08:37 PM   #11
abbas_m3
My Ride: bmw m3
Thanks for the info, I took my diff to a shop around a month ago and he mentioned the bracket that holds the cv joint (don't know what's it called) was really worn. So I just took the mechanics advise and got a whole new diff.
Dropped of the car to the mechanic this morning, hopefully the new diff fixes the vibration and everything is smooth again after that.
Old 07-09-2012, 02:43 AM   #12
nick0780
My Ride: 2004 M3
So how did it go? Is your problem fixed?
nick0780 is offline   Reply With Quote
Old 07-09-2012, 03:46 AM   #13
abbas_m3
My Ride: bmw m3
Yup problem was fixed a while back.
*****NOTE*****
The diff carrier bearings never cause this problem. The average mechanic will tell you this is a problem etc etc, however this is normal.
Back to my issue, after buying a diff and a new tail shaft it turned out my tyres had flat spots in them. That was the most f*cked thing that I have ever experienced !!!
Old 07-01-2014, 01:28 AM   #14
wsm
My Ride: bmw e46 m3
Send a message via ICQ to wsm
bmw m3 e46 smg diff
My diff has a hard kick when volume button on the smg is at full,the macahnic told me the diff has play,and I need a new diff,can the diff be repaired instead
wsm is offline   Reply With Quote
Old 07-01-2014, 04:42 AM   #15
Commando
My Ride: M3 - SMG
Yes the diff crown and pinion can be adjusted. However this is normally not required once the diff is built and begs the question where did the play come from. Perhaps bearings if you are lucky or possibly the play is not between the crown and pinion. The LSD unit is a replacement item. Has your diff done a lot of work?
Commando is offline   Reply With Quote
Old 07-01-2014, 07:08 AM   #16
wsm
My Ride: bmw e46 m3
It has about 100000km on it,The bearings were changed about a year ago
Old 07-01-2014, 08:55 PM   #17
Commando
My Ride: M3 - SMG
I would be check the crown - pinion set-up. Something may have shifted or the pre-load on the bearings may have been set wrong. As you already know the bearings can be replaced. Crown and pinions in various ratios are also available.
