Old 07-18-2013, 01:46 PM   #41
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
^Technique Tuning Turbo for the non-m
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 07-18-2013, 06:37 PM   #42
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
Originally Posted by bimmerguy055 View Post
If you keep the boost in the single digits and medium to low timing you should be fine with the stock head bolts. Any higher I'd suggest head studs (ARP or raceware) to keep the head down
It's not about the Stock head bolts stretching. It's about the aluminum block threads when the ARP bolts are in. Has anybody had the issue when the threads strip right out of the block?
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 07-18-2013, 06:57 PM   #43
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
Rocklee,
Your question was not specific about the head rising.. nor did you mention your power goal.. I have not had any issues with raceware head studs lifting or thread strip BTW.
and ARP does not make "bolts" but studs for the head FYI.
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
Old 07-18-2013, 10:56 PM   #44
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by bAby norAA View Post
isn't this an M?
I can't think of any turbo M3 "KIT" that makes that much torque below 4500 RPM.
Old 07-19-2013, 12:35 AM   #45
Commanderwiggin
My Ride: 900rwhp Turbo M3
I can't think of any turbo M3 that makes that much torque below 4500 RPM.
Ahem
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 07-19-2013, 02:53 AM   #46
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Originally Posted by Commanderwiggin View Post
Ahem
You got me there.
I was only thinking of the HPF and TT kits...
Old 08-02-2013, 09:24 AM   #47
ATLZHP6M
My Ride: TS2+ ZHP, ESS E39 M5
Decided to take the ZHP to my local Dyno shop to get numbers in before I install my bimmerbrakes headers and upgrade my fuel pump and fuel injectors.
I'm very happy with the results, considering the car has stock exhaust manifold.
Kit/Stage: ESS TS2+ 8.5 PSI
Other Power adders: UUC Lightweight Flywheel, TSE3 Catback, BMW Performance intake
Type of Dyno: dynojet
Miles on car: 128k
Miles with S/C: >50k
HP: 320 WHP / *376 to the crank
TRQ: 280
Any issues? Not enough power!
*Based on this statement from ESS Website:
Correction factor for drivetrain loss is 15% above RWHP as seen in dynograph (RWHP/0.85)
Props to ESS for advertising real numbers. In fact, I should be getting a little more once the headers are in.
ESS TS2+ Street/Track Toy
ATLZHP6M is offline   Reply With Quote
Old 03-17-2014, 04:15 AM   #48
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
21 May 14: 357 Hp / 450 ft/lb - Dyno Dynamics
Engine: M52Tu28 (M54B30 going in when Clutch goes in)
Kit/Stage: ESS TS2.
Other Power adders: Custom 2.5" exhaust, E85, Haltech PS2000
Type of Dyno: Dyno Dynamics
Miles on car: 193K Km's (120K Miles)
Miles with S/C: 50K Km's
HP: 296 whp
TRQ: 410 ftlb
Any issues? Clutch slipping badly. (UUC Twin Plate on the way)
Temp when dynoed was 35+ deg celcius (95+ deg Fahrenheit)
Attachment 550357
cosmos328Ci is offline   Reply With Quote
Old 03-18-2014, 08:40 PM   #49
jdjg
My Ride: e39, m52tub30
any of you ESS guys knows how many PSI boost in your max WHP and WTQ???
regards,
jdjg is offline   Reply With Quote
Old 03-23-2014, 10:51 PM   #50
cosmos328Ci
TS3 pulley
regards,
I have the ESS TS3 pulley for 15.2 psi.
On my M52TU28, boost was around 16.2 psi. (lots of clutch slip)
I have know M54B30 and UUC Twin Clutch with the ESS 15.2 psi pulley, yet to be dynoed, car still in workshop as we speak.
Old 03-24-2014, 04:14 AM   #51
Twin_Turbo_S54
My Ride: M3
Mate, did you ever go on dyno Dynamics?
Thinking a ESS TS for 330xi, just want to see Dynamics figures in shoot out mode.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 03-24-2014, 05:51 AM   #52
zek926
My Ride: 325ti TS2+ / 320cd
Looking forward to results!
zek926 is offline   Reply With Quote
Old 03-24-2014, 06:40 AM   #53
cosmos328Ci
Yes my current dyno with M52TU28 engine and clutch slip is a Dyno Dynamics.
Name:	Thu 13 Feb 14. Throttle, E46_328_SC.jpg
Yes, I hope they will be worthy, my tuning man is a bit on the cautious side.
Old 04-02-2014, 04:01 AM   #54
cosmos328Ci
Attachment 551173
Dyno- Dyno Dynamics:
Well, got email today from tuner, 340+ whp on petrol 98 (93 in USA) with M54B30 and new UUC Twin Plate Clutch.
Eflex sensor is not reading correct, once fixed it will be dynoed for E85.
Getting there,.. slowly.
Old 04-02-2014, 08:10 PM   #55
pokeybritches
My Ride: G-Power Z4M, VF Z4
M54B30
VF Engineering 6 psi kit
Supersprint headers (ceramic coated), Y-pipe, race exhaust
G Power Z4M and VF Engineering Z4 3.0i
pokeybritches is offline   Reply With Quote
Old 04-08-2014, 01:05 AM   #56
cosmos328Ci
Engine: M54B30
Kit/Stage: ESS TS2. (using ESS 15 psi pulley)
Other Power adders: Custom 2.5" exhaust, Haltech PS2000
HP: 329 whp
TRQ: 424 ftlb
Dyno is of: Old M52TU28 on E85 (296whp) Vs New M54B30 on 98 Fuel (93 USA) (329whp)
Name:	1. new 98 RON vs old E85.jpg
Old 04-08-2014, 07:24 AM   #57
turbotalon1g
My Ride: '02 330i
What's the most power someone has made stock motor no headstuds? With headstuds?
turbotalon1g is offline   Reply With Quote
Old 04-08-2014, 05:57 PM   #58
bimmerguy055
My Ride: M3
As-far-as I know, I hold the power record for a M54B25 stock internals (w/head studs)
Keep in-mind I'm running on crappy 91, and very conservative timing.
For my dyno run, the spark kept going out at ~20psi so the car was limping at @371hp on a mustang dyno. when I have time to fix the spark/boost spike issue I should be seeing ~500hp @ the wheels
Old 04-08-2014, 06:14 PM   #59
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I remember how every a$$h*** told you that you couldn't do what you were planning on doing !!! ......I remember.
Look how well you've done now.
I find it so fascinating that it's always the guys that have know idea what they're talking about, that try to tell you / or anyone else that it Can't be done.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 04-08-2014, 06:18 PM   #60
bimmerguy055
My Ride: M3
Rob43
Thanks Rob! It means a-lot to see people like you take notice, and remember
