Old 04-17-2012, 11:04 AM   #1
dano17
My Ride: 2000 328i
Car pulls left when braking?
When Im at higher speeds and brake, the car pulls left hard. The higher the speed, the more it pulls. Anybody know what could be done of this?
dano17 is offline   Reply With Quote
Old 04-17-2012, 11:12 AM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
I have the same issue and I suspect theres something to do with brakes.
I am seeing more brake dust one side than the other so I think the brake pressure is not the same side to side.
Been thinking about rebuilding the calipers and rebleed the system.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 04-17-2012, 11:16 AM   #3
jcns
My Ride: California
could be brakes - how many miles on the car?
could be alignment - did you mod the suspension? did you hit a pothole(s)?
could be worn out suspension- how many miles on your suspension?
did you check tire pressure? yes, sometimes it's as simple as different tire pressures.
jcns is offline   Reply With Quote
Old 04-17-2012, 11:46 AM   #4
My Ride: Lexus
Your other car is a bagged passat.
Is this E46 of yours stanced by any chance? Any teenage lowering mods? If so, that's your answer.
In any event, replace your entire suspension.
Old 04-17-2012, 05:20 PM   #5
stolidog
My Ride: 2004 M3 6spd
I would say its either ruts in the road (tramlining of the tires). Or your FCAB's are worn.
stolidog is offline   Reply With Quote
Old 04-17-2012, 05:57 PM   #6
dano17
My Ride: 2000 328i
FCAB's?
Old 04-17-2012, 06:17 PM   #7
MercForHire
My Ride: M235i 6MT
front control arm ball joint problem. Causing one wheel are not aligned straight when braking.
My left ball joint is creaking and need replacement, so when i brake, the steer wheel turns left a bit,.
Old 04-17-2012, 06:23 PM   #8
mxchris727
My Ride: E39, E93 335
Send a message via ICQ to mxchris727 Send a message via AIM to mxchris727 Send a message via MSN to mxchris727
Front Control Arm Bushings
-Chris
I have a computer set up with DIS, TIS, SSS Progman, INPA, NCS Expert, WinKFP, and Tool32 with an EDIABAS interface; PM me if you want to stop by and code your car.
ISTA/P & /D is up and running!
mxchris727 is offline   Reply With Quote
Old 04-17-2012, 06:33 PM   #9
Gus330vrum
My Ride: 330ci
FCAB'S ... mine was replaced week ago. had same symptoms... now gone!
don't let mechanics tell you its rotors like 3 told me...even tough my rotors are due for replacement.... it brakes firm now! ....
DIY and you will understand what FCAB'S JOB DUTY is.
bmaparts.com < Affordable Price ^
Gus330vrum is offline   Reply With Quote
Old 04-17-2012, 06:35 PM   #10
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
dano,
Yes, it can be many reasons. I hope it's just terribly inaccurate air pressure, maybe combined with something else.
Start reading threads about braking, cabs, but first, just check your air pressure. If you did hit a pothole, you could have smashed a cab on one side...and that would tend to make the car pull towards that side.
Anyway, read up on stuff...you'll have to start getting into it, because it's certainly something.
Also, don't ignore Mango entirely...just the way he says what he says! He's on his 'teenage' routine this week. Last week he wanted to know if OPs owned beagles...I'm not sure what that was about, but it seemed odd.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 04-17-2012, 06:37 PM   #11
Gus330vrum
My Ride: 330ci
Old 04-17-2012, 07:13 PM   #12
keepbreakindown
My Ride: 1999 323i
I had the exact same problem. Had it aligned twice, full suspension and brakes look over and everything was ok. I checked the tread depth on front tires and the driver's side was slightly more worn than the passenger. I swapped the two sides now it pulls to the right. New set of tires next payday. It's not an ideal solution but it was definitely the cause of my problem
keepbreakindown is offline   Reply With Quote
Old 04-17-2012, 07:30 PM   #13
rcsummers
My Ride: M3
i had the same problem. The brake fluid pressure was uneven. I had my pads, rotors, lines and fluid changed. The problem went away.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 04-17-2012, 07:37 PM   #14
325inthe510
My Ride: 152ci of madness
UMAD BRAH DON'T BE HATING ON MY JDM STYLE YO
-dano
325inthe510 is offline   Reply With Quote
Old 04-17-2012, 07:48 PM   #15
steve.k
My Ride: 05' 325Ci, 13' WRX
just going off the first post... 1. warped rotors 2. alignment 3. wheel balance
steve.k is offline   Reply With Quote
Old 04-17-2012, 09:11 PM   #16
IxNay
My Ride: 2000 328Ci 5sp SP
or 4. sticky caliper
IxNay is offline   Reply With Quote
Old 04-17-2012, 10:54 PM   #17
jkahng
My Ride: 02 330ci 5spd zsp
can someone explain to me how warped rotors make you pull to one side?
warped rotors would vibrate at high speed, not pull to one side when braking.
mis-aligned car pulls to one side all the time,
wheel balance should make it vibrate but only at a certain speed...
sticky caliper or guide and or FCAB makes more sense...
jkahng is offline   Reply With Quote
Old 04-17-2012, 10:58 PM   #18
Kris.R
My Ride: 2012 Dodge Charger
This. I had bad FCAB's before and you would only feel a quick "twitch" in the steering wheel towards the direction of the bad FCAB when applying the brakes.
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 04-17-2012, 11:12 PM   #19
djnekkon
My Ride: MB3ci & z33 HR
Warped rotors is the most common from all.
Old 04-17-2012, 11:32 PM   #20
choxor
My Ride: JDM
Is one of your wheels dusting more than the others? And if so is said wheel hot as hell after driving?
