Old 04-15-2012, 08:33 PM   #1
Flaboy239
My Ride: 2004 330ci
4.10 gears in a 6 speed...
I want more low end torque without risking my engine so I'm thinking of swapping out my 3.46 gears and installing some 4.10's or something close to it. Who's done it and what are my pros and cons?
Flaboy239 is offline   Reply With Quote
Old 04-15-2012, 08:55 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Here, if you haven't seen this, this is what you need to get started. Just input any combination you want.
http://www.bokchoys.com/differential...calculator.htm
Good luck,
Rob
SUMMIT POINT WV 1:24:229 SCCA
Old 04-15-2012, 09:10 PM   #3
Flaboy239
My Ride: 2004 330ci
Thanks! That helps. 3600rpm at 80mph isn't all that great but it would be a beast around town. It seems to be the only way I'm going to get the torque I want without sacrificing my engine.
Old 04-15-2012, 09:13 PM   #4
B_Cyrus
Banned User
My Ride: Malfouf
you can't legally go 100mph in the US, so why bother working on top end speed?
B_Cyrus is offline   Reply With Quote
Old 04-15-2012, 09:24 PM   #5
Flaboy239
My Ride: 2004 330ci
Ya I rarely go 100mph. Your asking to go to jail. Not that I don't still do it at times tho. I love speed but I prefer useable 0-60 speed over top end speed that is basically useless. My only concern was cruising around town at 4000rpm and first gear being to touchy to even use.
Old 04-16-2012, 03:50 PM   #6
MSportBMW
My Ride: E46 325, EVO8 MR
Theres another calculator on diffsonline mske sure you punch the numbers in for an estimate of running/gear speeds. But 4.1 with a 6 speed should be fine
MSportBMW is offline   Reply With Quote
