E46 Xi Forum
Old 04-18-2012, 02:08 PM   #1
mvitale27
My Ride: '02 330xi
clunk coming from rear after shock replacement
just like the title states, i had my rear shocks replaced and now there is a clunking noise anytime i go over any type of small bump in the road. i searched this and found many threads but none with a solution. can anyone point me in the right direction?
mvitale27 is offline   Reply With Quote
Old 04-18-2012, 02:15 PM   #2
SamDoe1
My Ride: 4cyl of fury
Did you replace upper shock mounts? If no, they are broken. If yes, you didn't tighten them up properly.
Did you put that cone shaped washer on the right way? It should be backwards of the way it seems like it should go.
Did you break or detach a sway bar end link?
Did you tighten everything to torque spec with a calibrated torque wrench?
Best way to find out what's clunking is to jack the car up and start shaking things. Should be fairly obvious when you do that.
Old 04-18-2012, 02:19 PM   #3
Kubica
My Ride: 2003 325xi
+1.
Plus...torque everything down with all four wheels on the ground, and make sure the brake backing plate didn't get bent.
Old 04-18-2012, 02:30 PM   #4
mvitale27
My Ride: '02 330xi
thanks for giving me some things to check out! i didnt do the work myself so i cannot answer those questions. i'll start with the rsm's and work my way from there
Old 04-18-2012, 02:31 PM   #5
mvitale27
My Ride: '02 330xi
Everything you said makes sense except why would replacing the shocks automatically mean the rsm's are broken?
Old 04-18-2012, 02:45 PM   #6
TR4G-
My Ride: '01 325xi, '90 325iC
is it more of a clunk or a rattle sound? I replaced my RSMs and put in coilovers, and still have this rattle. I believe its my RTABS. Replacing them this time tomorrow! I'll check back with updates!
TR4G- is offline   Reply With Quote
Old 04-18-2012, 02:49 PM   #7
SamDoe1
Judging by age of the car and location in which it's driven, it's very likely that the RSMs are toast. (assuming that they have never been previously replaced)
Old 04-18-2012, 03:53 PM   #8
mvitale27
My Ride: '02 330xi
It's definetly more of a clunk, a deeper pitched noise. When I think of a rattle, I think of almost a metal on metal higher pitched noise.
Old 04-18-2012, 03:56 PM   #9
mvitale27
My Ride: '02 330xi
Yea I am not sure if they ever have been previously since I bought the car last May. Judging by all the maintenace I have done it is probably safe to say they haven't. Would you recommend replacing them with OEM or aftermarket? Although I just replaced my rear shocks with OEM.. I payed parts only, no labor.. I have been thinking of upgrading to konis/eibachs this summer when I get some new wheels (style 135s?)
Old 04-18-2012, 04:16 PM   #10
SharkmanBMW
My Ride: 03 330xi, 4th bimmer
Send a message via MSN to SharkmanBMW
Other than RSMs, which are likely at least part of the problem...
Do both sides clunk or only one side?
Were the new shocks actually 'new'?
What kind?
If the shocks installed were not identical than the ones removed it could be the cause. Maybe they installed a non-xi part?
Also check rear spring/spring pad is seated properly
These cars notoriously break rear springs, worth a look
H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs
SharkmanBMW is offline   Reply With Quote
Old 04-18-2012, 04:35 PM   #11
TR4G-
ok good, I agree with that. So our noises are definately not the same
Old 04-18-2012, 05:14 PM   #12
SamDoe1
I did OEM + reinforcement plates. There are others out there, but I didn't see the need to pay that much more.
Old 04-18-2012, 05:49 PM   #13
Kubica
My Ride: 2003 325xi
Originally Posted by samdoe1 View Post
i did oem + reinforcement plates. There are others out there, but i didn't see the need to pay that much more.
+1.
Old 04-19-2012, 09:13 AM   #14
mvitale27
My Ride: '02 330xi
I replaced my RSM's with OEM and a reinforcement place and then retightened almost every nut and bolt on the rear suspension. Clunk is gone. Not really sure what did it because I didn't test drive at each point, but I'm just glad it's gone.
I believe the shocks that were installed were Sachs? I could be mistaken. It was 11:30 last night when I got home from school and started doing this.
Old 04-19-2012, 09:30 AM   #15
SamDoe1
Nice work.
Old 04-19-2012, 09:59 AM   #16
mvitale27
My Ride: '02 330xi
YAY 1 more problem solved.. 99 to go!
Old 04-19-2012, 10:13 AM   #17
CharlzO
My Ride: 2000 328ci
99 Problems but a RSM ain't one!
CharlzO is offline   Reply With Quote
Old 04-19-2012, 11:00 AM   #18
mvitale27
My Ride: '02 330xi
I might have to put that in my sig!
Old 11-14-2012, 01:02 PM   #19
Gepetto
My Ride: 2004 325i
I have the same problem. Recently (August) changed shocks and struts with Bilstein HD set from Tunermotorsport.com. Also got RSM's from them that are aftermarket (). Could these be the culprit? The car handles great now, just this weird clunk noise...I had a local dealer to the install as I didn't have a garage at the time, nor the right tools.
Gepetto is offline   Reply With Quote
Old 11-14-2012, 05:02 PM   #20
SamDoe1
Do the following. Especially the last one.
