///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 04-20-2012, 09:30 PM   #1
AlbertM3
My Ride: 2004 M3
3 sets of tires in 1yr... Some help please
Alright i have a 04 m3 with 35k miles on it. I have had the car for almost one year and have burned through 3 sets of rear tires. The tires wore down on the inside part of the tire. I have done 3 full alignments and changed out the rear control arm bars. The stock 19 are on it and these last set of rear tires lasted about 3 weeks so it seems to be getting worse.
So wtf should I do now? I'm spending all my beer money on tires! Gonna take it back to my alignment guy tomorrow.
AlbertM3 is offline   Reply With Quote
Old 04-20-2012, 10:08 PM   #2
sr71blackbird92
My Ride: 2004 325i - 2002 M3
Ummm... How exactly are you driving it?
If you put soft sticky tires on it and squeal them around every corner, then they will wear out much faster.
02 M3 Mod List: 19" Wheels - OEM CSL Bumper - CSL Steering Wheel - eBay Headers - Angel Eyes - Carbon Fiber Interior Wrap - Smoked Corners - apparently some sort of tune since it hasnt noticed the lack of cats.. >_>
2004 E46 325i - Sold | 1997 E39 540i6 - Sold
sr71blackbird92 is offline   Reply With Quote
Old 04-20-2012, 10:48 PM   #3
AlbertM3
My Ride: 2004 M3
Drive it like an old man. Just cruise. Got normal michelin tires.
Old 04-20-2012, 11:13 PM   #4
$ilent ///M
My Ride: 03.5 M3 smg lsb
Does the alignment reading keep changing each time you get it done? If it does, your bushing are wearing
$ilent ///M is online now   Reply With Quote
Old 04-20-2012, 11:18 PM   #5
XKxRome0ox
Black and Proud
My Ride: a franken-e46 325i
and what have you checked so far? did you get an alignment each time you replaced your tires?
check for bent wheels too
Posted from Skyrocket using BimmerApp
XKxRome0ox is offline   Reply With Quote
Old 04-20-2012, 11:34 PM   #6
tuscan1205
My Ride: 325CI
35k is still really low... but... it could be bad fcabs and rtabs. also try to get a tire with a 500+ tread rating. the tires will feel a bit stiffer, but they will last a lot longer.
tuscan1205 is offline   Reply With Quote
Old 04-21-2012, 02:46 AM   #7
illestminimike
My Ride: 2003 SMG Vert M3
I'm gonna say RTABs. Upgrade to the powerflex ones.
-2003 M3 Vert
-1967 Mini Cooper
Old 04-21-2012, 06:04 AM   #8
AlbertM3
My Ride: 2004 M3
Yes I got the alignment after each new set of tires.
I'm haven't checked of the specs changed at all after each alignment I'll look into that.
Old 04-21-2012, 06:15 AM   #9
Busabos77
My Ride: 04 Tiag M3 E46
Powerflex (RTAB) rear trail arm bushing...
Old 04-21-2012, 09:56 AM   #10
illestminimike
Originally Posted by AlbertM3 View Post
I haven't heard of the powerflex rtab
Search.
-2003 M3 Vert
-1967 Mini Cooper
Old 04-22-2012, 01:15 AM   #11
emm3speed
My Ride: 2005 m3
3 sets in 1 year. Come on man if someone slaps you in the face dont you want to know who did it?
before you buy new tires or go to an alignment guy search rtabs. they are your problem. ask around for quote on having them installed. Buy them and have them install. then buy your tires and get an alignment.
emm3speed is offline   Reply With Quote
Old 04-23-2012, 11:35 AM   #12
wilsel
My Ride: 05 AW M3 ZCP
My guess is something is worn out causing your rearend not to be in alignment when driving. Usually its the RTAB's, but 35k is kind of low for them to go. You need to visually inspect all the rear bushing for cracks.
wilsel is offline   Reply With Quote
Old 04-23-2012, 01:21 PM   #13
mannyaplus11
My Ride: 2003 LSB M3 Vert
I had the same problem.
I replaced the RTAB's. No more problem.
mannyaplus11 is offline   Reply With Quote
Old 04-23-2012, 02:08 PM   #14
AlbertM3
My Ride: 2004 M3
Thanks everyone gonna try to swap the rtab's this week.
Old 04-23-2012, 05:42 PM   #15
sakumaxp
My Ride: 02 M3 convertible
RTABS are done for, powerflex is the way to go, get the polyurethane ones, i had your same problem, i got those and did an alignment and so far so good
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 04-24-2012, 09:51 AM   #16
AlbertM3
My Ride: 2004 M3
I ordered the rtabs lst night. hopefully it fixes the problem. this is a pic of the tire that i bought about 5 weeks ago
Old 04-24-2012, 10:40 PM   #17
wildpig
My Ride: 2003 BMW M3 Convert
So for all of yall out there, is there any other way of knowing if your rtab need replacing beside just early tire wear? I mean can this be determined visually by taking the tires off somehow?
2003 BMW M3 Convertible
wildpig is offline   Reply With Quote
Old 04-24-2012, 11:51 PM   #18
emm3speed
My Ride: 2005 m3
Attachment 448180
What size wheels an tires and what do you have your rear camber set at?
Old 04-24-2012, 11:56 PM   #19
illestminimike
Does your car move to one side when you stomp on the gas? Or dive to one side when braking?
And when changing lanes, does it feel like the back end is going to come out?
-2003 M3 Vert
-1967 Mini Cooper
Old 04-25-2012, 07:49 AM   #20
808elise
My Ride: OG E46 M3/AW E46 M3
Yes. Take it to a good shop that knows BMW or German engineering in first place. If u upgrade to coilovers or especially diff springs just change immediately. By all means do not go through 3 sets of ps2s in a short amount of time like that. IMO this is one of the first things that should b done to these cars. Just do it right away when u buy it.
My Journal I
VORSTEINER - APEX - BREMBO - FORTUNE-AUTO - ESS 550/METH
M///
My Journal II
VFE570 - DIXIS - TWC WIDEBODY - AP RACING - KW V2
M///
808elise is offline   Reply With Quote
m3, tires, ware
