///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 04-25-2012, 03:17 PM   #21
sakumaxp
My Ride: 02 M3 convertible
Originally Posted by wildpig View Post
So for all of yall out there, is there any other way of knowing if your rtab need replacing beside just early tire wear? I mean can this be determined visually by taking the tires off somehow?
also when your cornering at highspeed your car might, "wiggle"
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 05-05-2012, 07:45 PM   #22
AlbertM3
My Ride: 2004 M3
Update :
Put on the Powerflex rtabs today. The were pretty shot. Got two used 255 35 19 tires for 50$ each so I can In case the problem isn't fixed. Going to go an get another alignment on Monday. Hopefully this fixes the problem. Anything else I am missing here????
AlbertM3 is offline   Reply With Quote
Old 05-05-2012, 07:51 PM   #23
wilsel
My Ride: 05 AW M3 ZCP
If you haven't changed the FCAB's I would. They are probably shot as well.
wilsel is offline   Reply With Quote
Old 05-05-2012, 08:35 PM   #24
AlbertM3
My Ride: 2004 M3
Same Powerflex ones I'm assuming?
Old 05-05-2012, 08:42 PM   #25
illestminimike
My Ride: Project Drama
Yup.
Old 05-05-2012, 09:01 PM   #26
wilsel
OEM is my preference. Polyurethane is to harsh a ride for me.
Old 05-06-2012, 08:43 PM   #27
mikejohnsonm3
My Ride: m3
I just went through this!!! take the car to bmw and make sure they print out your papers. I took mine to 2 other shops and they didnt do my alignment right. BMW will get it right! or tell you what parts youll need. its only $130 for a bmw alignment
mikejohnsonm3 is offline   Reply With Quote
Old 05-06-2012, 10:00 PM   #28
emm3speed
My Ride: 2005 m3
I'm surprised poly would be harsh of a ride considering its part in the suspension system. Id bet dropping tire psi 1-2 lbs would negate any harshness (probably overkill at -2 psi). Nvh though can't really argue with I'm sure it's more with poly although if anyone listens to music or knows what a cd player is its probably not an issue.
Glad to see you got it sorted. Remember you 'should' be doing an alignment on new or evenly work tires I hope your new used ones are worn evenly.
emm3speed is offline   Reply With Quote
Old 05-06-2012, 10:44 PM   #29
emm3speed
My Ride: 2005 m3
I agree if your rtabs are shot fcabs are probably worn although the issue seems to be with the rears primarily.
I'm not all that familiar if it's common on the e46 chassis but the rear lower control arms on other cars I've had sometimes don't hold their camber when worn. I've had an alignment once where the camber was set and when I drive away my camber looked crooked. I went back and sure enough the adjustment bolts were worn and wouldn't hold a setting.
I went and bought a rtab tool, the same poly rtabs and adj control arms. I'm going to be switching my new winter fronts to the back to make sure the alignment machine gets it accurate and then I'll put my rims on. Then I'll be buying new tires.
Old 05-07-2012, 09:37 PM   #30
AlbertM3
My Ride: 2004 M3
Originally Posted by illestminimike View Post
Yup.
Should I get the Control Arm Bushing that already comes with a Bracket? Is it necessary to change out the brackets?
Old 05-07-2012, 09:38 PM   #31
AlbertM3
My Ride: 2004 M3
thanks, didn't know that.
Old 05-07-2012, 09:39 PM   #32
AlbertM3
My Ride: 2004 M3
cool, my place charged me 65 but not planning on going there anymore. i'm gonna call bmw in the morning.
Old 05-07-2012, 09:48 PM   #33
illestminimike
It'll make life easier.
Old 05-22-2012, 11:43 AM   #34
the fly
My Ride: '95 m3, '03 m3
See above -- what he said.
To that end, I am selling factory bushings pre-pressed into used housings. See the below link...
http://www.m3forum.net/m3forum/showthread.php?t=376064
the fly is offline   Reply With Quote
m3, tires, ware
