Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 04-21-2012, 03:57 AM   #1
02PRUV
My Ride: E46 M3 Turbo
Twin Intank Pumps
I thought someone had done twin intank pumps before but doing a search I can't find it.
Anyone remember who did it and if there were pics of it.
I need to do something now because I've run out of fuel at 500whp @ 15psi on E85 with one pump today.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 04-21-2012, 05:26 AM   #2
Bdave
My Ride: M3 HPF Stage 3
You dont need two pumps, just one big one. Check with HPF to see if this one is big enough. They offer bigger ones..
http://www.horsepowerfreaks.com/part..._In_Tank/16889
From what I can find out, the 255lph is just adequate for your situation. That means you should look for a 300lph pump that fits in tank, if such a beast exists. E-85 is tricky. My info is from reports i read not from a real expert. Check with a really knowledgeable tech. But I think I got you in the ball park at least. GL.
(My pump is 1250 lph!)
EDIT: Bimmerworld offers dual in tank pumps, but for starvation reasons. You give up your fuel gauge when you use them.
Bdave is offline   Reply With Quote
Old 04-21-2012, 05:37 AM   #3
basar13
My Ride: Z4M, R8, 525xd, STI
Why dont you want a inline pump ? is it because of noise ? Just put a bosch 044 inline
What pump do you have in your tank ?
basar13 is offline   Reply With Quote
Old 04-21-2012, 06:29 AM   #4
02PRUV
LOL I have a 320lph in tank pump now and it's the one that has run out. I really need two of these.
Rides:
Old 04-21-2012, 06:32 AM   #5
02PRUV
DeatschWerks DW300. Not a fan of inline setup. Not even a fan of twin pumps. But I'd rather do twin than inline.
Rides:
Old 04-21-2012, 06:45 AM   #6
Littleturbo
My Ride: Car
Do you have it wired directly to the battery?
Littleturbo is offline   Reply With Quote
Old 04-21-2012, 07:05 AM   #7
02PRUV
LOL yes. Like I have said many times and people don't want to believe me this is around the 800whp mark on a US dynojet. It's out of pump.
Rides:
Old 04-21-2012, 07:13 AM   #8
Bdave
E85 can be crazy in its demands. I did not want to take a chance and went BIG when I made the decision on my fuel cell pump. I bought the one with the built in eliminator, 1250lph.
I have heard great things about DeatschWerks pumps. One guy is running 3x300lph on his project.
So, 02PRUV, you think 2x300lph should be plenty for 500hp on E85? Or the OEM plus an inline 300lph DeatschWerks?
I have not hear much about twin in tank pumps except for the Bimmerworld set up.
Edit: if u are at 800rwph u will need 3x300lph or a single 1000lph pump. I assume you are trying to feed 2150cc injectors? 1100cc injectors dont need near as much fuel.
You need to be looking at some type of pump controller working on a wave modulation principle like Aeromotive's pump controller.
Old 04-21-2012, 07:27 AM   #9
02PRUV
I was thinking 2 x 320lph DeatschWerks in tanks should get me around the 600whp @ around 20psi on E85 which is about all I will push it.
It's feeding ID1000 injectors @ 45psi base fuel pressure.
My injectors were at 80% duty cycle at this hp. So whatever it gets with an extra pump is all it's going to get.
Rides:
Old 04-21-2012, 08:01 AM   #10
Bdave
Only 1000cc? Yep..2x320 is fine.
Old 04-21-2012, 09:22 AM   #11
SlideFox
My Ride: A Bucket w/ 4-Wheels
Originally Posted by Reid@SP View Post
Maybe this.....
SlideFox is offline   Reply With Quote
Old 04-21-2012, 02:28 PM   #12
jacobs323i
My Ride: blown 323i
really what pump?
jacobs323i is offline   Reply With Quote
Old 04-21-2012, 02:30 PM   #13
jacobs323i
My Ride: blown 323i
weird I have the exact same pump and I have plenty of room to go higher at 500 rwhp, i am also using e85 and fic 1100 injectors.
Old 04-21-2012, 06:51 PM   #14
02PRUV
That's cause 500whp in the US is about 380whp here. So yes you wouldn't be out of pump at that horsepower. If you got it up to 750-800whp on a dynojet you would find your out of pump.
Rides:
Old 04-21-2012, 06:59 PM   #15
02PRUV
Originally Posted by SlideFox View Post
Maybe this.....
That looks impressive but I'm not a fan of inline pumps. I have found problems before when the intank pump can't supply enough fuel to the back of the inline pump it has really bad side affects.
I've also seen it where pressure builds up between the pumps and super heats the fuel and gives the inline pump a heart attack.
These are the two reasons I don't like inline pumps.
What I want to try and do is do twin pumps on the factory fuel pump hanger in the tank. I thought I'd seen it done before on here but maybe I'm thinking of somewhere else. Might not of been a BMW.
Rides:
Old 04-21-2012, 08:19 PM   #16
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I've heard of using another fuel pump hanger assembly on the driver's side.... doubling up with a pump on each side. You lose the syphon system, and the fuel level sender, but I don't think this would be a worry for you?
I've also seen some people tap into the side of the plastic fuel tank with a bulkhead fitting and an inline pump....but I think this is a really bad idea.
Old 04-21-2012, 08:38 PM   #17
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
I think much better than running two pumps or modifying anything in the tank is doing what you did in the trunk. I think the OP should look more into surge tank methods of supplying fuel. The double pickup is something that has been done, but I wouldn't put the pumps inside the tank, the above fuel system is gorgeous, I would try to emulate that if i didn't want a surge tank.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 04-22-2012, 07:40 AM   #18
Littleturbo
My Ride: Car
Something like this?one pump each side
Name:	fuelsystem  2 pumps.jpg
Old 04-22-2012, 08:03 AM   #19
Bdave
Yep. I am pretty sure that would make the OP happy. Looks fine. But you lose your gas gauge dont you? Your fuel level sender is where you hang the second pump, correct?
This is Bimmerworld version:
http://store.bimmerworld.com/e46-fue...kits-p343.aspx
no pix however...
I did find this pix of an OEM set up showing the fuel float sender located in the second fuel tank port:
http://forums.bimmerforums.com/forum...d.php?t=752438
The dual pump set up solves fuel starvation. You COULD rig up a sender based on a whole custom set up. They make all kind of ways to to read fluid levels. You may have a remote gas gauge, but it would be better than nothing.
Old 04-22-2012, 11:18 AM   #20
Littleturbo
My Ride: Car
[QUOTE=Bdave;14317429]Yep. I am pretty sure that would make the OP happy. Looks fine. But you lose your gas gauge dont you? Your fuel level sender is where you hang the second pump, correct?
Fuel gauge works fine,on both fuel pump holders there is a connection wich meassures the fuel level.
I will try to make a picture of it.
