Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 04-22-2012, 01:35 PM   #21
JackEatsEmoKids
My Ride: '02 E39 530/5
Send a message via AIM to JackEatsEmoKids
http://www.ebay.com/itm/Walbro-400LP...item1c2637a077
400lph in tank maybe?
- BMW Master Certified Technician -
'02 530i - PTE6262 - MegaSquirt3X - E85 fuel -
596whp/558ft-lbs @ 22psi
JackEatsEmoKids is offline   Reply With Quote
Old 04-22-2012, 01:43 PM   #22
Bdave
My Ride: M3 HPF Stage 3
[QUOTE=Littleturbo;14317745]
Originally Posted by Bdave View Post
Yep. I am pretty sure that would make the OP happy. Looks fine. But you lose your gas gauge dont you? Your fuel level sender is where you hang the second pump, correct?
Fuel gauge works fine,on both fuel pump holders there is a connection wich meassures the fuel level.
I will try to make a picture of it.
Where did you get that set up? Very cool. This is a nice alternative to a surge tank too.
Bdave is offline   Reply With Quote
Old 04-23-2012, 12:24 AM   #23
02PRUV
My Ride: E46 M3 Turbo
I pulled the syphon side out today to see what was there. There is no surge bowl area for a pump. But the biggest issue is I was showing just under 1/2 a tank on the gauge and that's exactly where the fuel was as well. All on the fuel pump side. There was no fuel at all on the syphon side. So I wouldn't like to put a pump on that side because it would run dry and have no surge area. So back to what I was looking at I'm going to run 2 pumps on the one hanger.
Now the joy of trying to make it all fit.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 04-23-2012, 01:05 AM   #24
MrBlonde
My Ride: M Coupe
You want lift pumps up to a surge tank and then inlines from the surge to the fuel rail. I've got the OEM intank pump, then two Carter lift pumps, twin surge tanks and then four 044 inlines going forward.
.-=[ Kenny ]=-.
1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph) - pass made 25th August 2004.
See the E46F Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube.
Everything you need to know about Drag Racing your BMW street car
MrBlonde is offline   Reply With Quote
Old 04-23-2012, 04:17 AM   #25
02PRUV
That might be what I need but it's what I don't want. Don't want to take up boot space with fuel system. It's a street car.
Rides:
Old 04-23-2012, 04:48 AM   #26
02PRUV
Getting there. After a lot of cutting and hacking thery are sitting at the right level and now I just need a Y connector to join them up.
Rides:
Old 04-23-2012, 07:57 AM   #27
02PRUV
Finished and fitted. Now time for testing
Rides:
Old 04-23-2012, 09:27 AM   #28
SweTurbo
Big Pimpin'
My Ride: 323i -98
I doubt that will work out as good as running a Y connector outside the tank, mainly because the pumps will have to work against eachother , also a one-way valve should be fitted to the output of each pump..
It will outflow one pump though thats for sure
On a side note :
Is the Fuel level sensor thesame on both sides ?
If so you could just drop in another pump assembly on the driver side.
And whoever linked that 400LPH pump , it's rated at 40psi , i bet it drops really fast above that...
Old 04-23-2012, 01:42 PM   #29
02PRUV
On a side note :
I agree it's not a perfect situation but it will work. The pumps won't work against each other that much, liquid still will always take the path of least resistance. Walbro's do have a check valve on the output barb on the pump. I would of prefered to do a Y outside the tank but then I would of had to do a bulkhead fitting on the hanger top. And there isn't much room to do that. Then there isn't much room to do much above the tank either.
To be honest this is the best comprimise in a bad situation I believe. And if this doesn't work well enough then the only other thing to do will be use boot space and do a surge tank.
Rides:
Old 04-24-2012, 07:33 PM   #30
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
[IMG]...[/IMG]
sorry to go slightly ot, but all of this fuel system for a 30r on a s50b32?
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 04-26-2012, 08:05 PM   #31
quick108
My Ride: BMW
Here is a low profile twin Bosch 044 FST (front right)
quick108 is offline   Reply With Quote
Old 03-23-2013, 01:53 PM   #32
dgreen78
My Ride: 00' 323i
How did this setup work out for you? I'm planning on doing a 2jz/e85 and need to figure out a pump setup.
07' 997TT
00' 323i 2jz
dgreen78 is offline   Reply With Quote
Old 03-23-2013, 03:59 PM   #33
str8dum1
My Ride: VQ38DETT
how is the siphon system going to pull fuel from across the saddle connected to that chopped up fuel basket?
VQ38DETT on twin 6262 with ProEFI128
str8dum1 is offline   Reply With Quote
Old 03-23-2013, 06:20 PM   #34
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
Originally Posted by SlideFox View Post
Maybe this.....
This is the Saad Racing fuel system and this was the answer to your problem. Its not an in line system, it has its own line and maintains the original system so everything works in the saddle tank. I also have one available for a Supra.
Saad @ Saad Racing is offline   Reply With Quote
Old 03-23-2013, 06:26 PM   #35
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
This
Old 03-23-2013, 07:37 PM   #36
02PRUV
still working great
Rides:
Old 03-23-2013, 07:40 PM   #37
02PRUV
The siphon hose goes into the surge area on the pump side. Nothing to do with the basket
Rides:
Old 03-25-2013, 04:03 PM   #38
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
Awesome!
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 03-26-2013, 07:55 PM   #39
2filthy3
My Ride: e46 m3
Here is how e36 guys run twin pumps. LINK
Using a modified fuel pump hanger with a fuel pump installed, to go into the non fuel pump/venturi effect pump side, I.e. A pump each side.
Also here apparently e46 compatible, there are cheaper kit's but I am unsure if they are designed like this one, no pictures on their websites.
2filthy3 is offline   Reply With Quote
Old 03-26-2013, 10:10 PM   #40
FragNasty
My Ride: Car
Nice to you back and posting Bdave. It's been a while.
This is Bimmerworld version:
http://store.bimmerworld.com/e46-fue...kits-p343.aspx
no pix however...
I did find this pix of an OEM set up showing the fuel float sender located in the second fuel tank port:
http://forums.bimmerforums.com/forum...d.php?t=752438
The dual pump set up solves fuel starvation. You COULD rig up a sender based on a whole custom set up. They make all kind of ways to to read fluid levels. You may have a remote gas gauge, but it would be better than nothing.
FragNasty is offline   Reply With Quote
