Old 04-21-2012, 04:53 PM   #1
Flaboy239
My Ride: 2004 330ci
Where to buy 4.10 ring and pinion?
It's for my 2004 330ci with LSD. I've found one website and it was $800. Anyone know of some places I can look?
Flaboy239 is offline   Reply With Quote
Old 04-22-2012, 10:46 AM   #2
Blocked Out
My Ride: Imola 330i M-Sport
Which brand LSD do you have now ?
Wait, your car is SC and you want 4.10s? You must be crazy . You wont be able to drive the car after that
Original BMW Teile ///
IMG_1725
Old 04-22-2012, 10:53 AM   #3
Flaboy239
My Ride: 2004 330ci
Koala?? I bought the car with it. I have 3.46 now and I don't see 4.10 being an issue. I may settle for 3.90 or something.
Old 04-22-2012, 11:55 AM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
If you have a Koala diff, just send it back to Brett and let them rebuild it with whatever gears you want to run (he warranties his builds).
You have an auto or manual? If manual, the 4.10 does seem a bit short IMHO - I'm running a 3.64 and can't imagine going any shorter in a daily driver. Of course, I've also got a lot more low and mid range torque with my TS than you do with the centri and I know that's what you're trying to compensate for.
Old 04-22-2012, 01:27 PM   #5
Flaboy239
My Ride: 2004 330ci
Ya it's a 6 speed. I have no low end torque and that's exactly why I'm doing it. According to the gearing calculator I used it shouldn't be to bad. I don't do a lot of highway driving and I mostly cruise around about 50 mph. I'll check out kaola. I don't really want to be without a car for any extended period of time either.
Old 04-22-2012, 04:06 PM   #6
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Here.
http://www.diffsonline.com/product/gearsets.shtml
Good luck,
Rob.
SUMMIT POINT WV 1:24:229 SCCA
Old 04-22-2012, 04:57 PM   #7
Flaboy239
My Ride: 2004 330ci
Originally Posted by Rob43 View Post
Why are 3.91's so cheap??!!!! That just might be the way I go!
Old 04-22-2012, 05:19 PM   #8
Rob43
Rob43's Avatar
I don't know, why don't you just ask.
3.91 = 13%
4.10 = 18.5%
Good luck,
Rob.
PS, tell Dan I say hi.
Old 04-23-2012, 03:31 AM   #9
MSportBMW
My Ride: E46 325, EVO8 MR
Last I checked Dan can hook you up with a well-priced 3.64 gear set at a good price
MSportBMW is offline   Reply With Quote
Old 04-23-2012, 08:38 AM   #10
Flaboy239
My Ride: 2004 330ci
I had a Chevy s-10 that I swapped out the 3.42 gears for a set of 3.73 and I literally could not tell the slightest bit of difference. I felt as if I wasted time and money.
Old 04-23-2012, 09:13 AM   #11
TxZHP04
That's almost a 10% change in the diff ratio. When I went from the stock 3.07 to a 3.23 (about 5%), the difference was very noticeable. When I went from 3.23 to 3.64 (over 12%), the difference was huge.
FWIW... you probably didn't notice much difference in the S-10 because the transmission itself was probably geared much taller than in the BMW. For example, 1st gear is 4.35 for the e46 6-spd. GM used a number of different transmissions for the S-10 with 1st ranging from about 2.75 to 3.49 depending on application. The shorter gearing in the BMW transmission is going to multiply the diff ratio change making whatever % change in the diff ratio that much more noticeable than the effect you got in the S-10 (remember, the final drive ratio is the product of the transmission and diff ratios). An X% diff ratio change still results in an X% change in final drive ratio but 10% of 15 is going to be larger than 10% of 10.
