Old 04-23-2012, 12:19 AM   #1
fraser19
My Ride: 2004 330CI M sport.
Innovative MTX-L Wideband controller
What do you guys think about upgrading to a better wideband controler?
I have been reading about this for a little while and while what the company says it will do sounds great what are some more real life restults.
Here is one of the articles I have read.
http://www.innovatemotorsports.com/r...s/AN19_1.2.pdf
Here is what im looking at
http://www.innovatemotorsports.com/products/MTXL.php
It is just a better verson of the LC-1 that i have seen a few guys running in their Ci's and M3's.
1) Rapid load-transition Periods. Due to the slow response time of PID systems, even the most
sophisticated modern vehicles must go “open-loop” for up to 500ms second after major throttle
transitions (for example, “Acceleration Enrichment” period). Such open-loop operation often results in
excessive fuel injection (and therefore reduced MPG, and increased emissions) during transitions. In
most regular driving, transitions are quite frequent. It is estimated that eliminating open-loop
operation acceleration enrichme
Sounds nice
The benefits of full-time closed-loop operation are clear- essentially you have a self-tuning, adaptive engine
that can handle major variations in fuel composition, barometric pressure, and component aging.
Well wouldn't that be nice.
Those are some of the worth mentioning points I found but really what do you guys think?
fraser19 is offline   Reply With Quote
Old 04-23-2012, 02:26 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Sounds nice
I'm sure that will work just fine.
I run the Auto Meter #4378, it's 50% more expensive than the Innovate Motorsports one, the #4378 has a user programmable safety feature that I really like. Lets say you set the "Peak" AFR number to 14 (you can set the ALARM to trigger at ANY number you want) when at W.O.T. on the Auto Meter, if something goes wrong & you start to run lean & it hits this pre-programed number of yours, the unit will start to rapidly flash "ALr" (Alarm) to warn you. It also has a W.O.T. peak / recall feature explained below. Play video from link.
http://www.autometer.com/cat_gaugede...id=3604&sid=11
Wide Open Throttle Alarm/Warning Mode:
"Alarm/Warning mode enables you to program a visual alert point into the gauge in order to warn you of when air/fuel mixtures are running dangerously lean in your vehicle’s engine. The visual alarm or warning activates when the AFR or Lambda reading reaches or exceeds your programmed alarm point. When the alarm activates the bar graph display will blink rapidly to warn the driver of the Alarm condition."
Wide Open Throttle Peak/Recall Mode:
"WOT Peak/Recall mode provides you with a quick and easy way to find out exactly how “Lean” your engine / vehicle got during the last pull, run, or race."
Good luck,
Rob.
SUMMIT POINT WV 1:24:229 SCCA
Old 04-24-2012, 11:16 AM   #3
fraser19
I see.
I guess my question is,
Does the wideband sensor and controller send the data to the ECU and then the ECU will take the better data and adjust engine function for optimal AR?
Or do you have to try and set this up on your own?
Its the
part that really grabbed my attention
Old 04-24-2012, 11:37 AM   #4
Rob43
Rob43's Avatar
I see.
Its the part that really grabbed my attention
No.
All of these "simple" $180 to $300 dollar devices are completely standalone, as in the don't tie into our BMW ECU's. I'd still call them up & talk with a Tech guy to ask what exactly that statement meant, that's me though.
Good luck,
Rob.
