Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 04-24-2012, 10:38 AM   #1
l8apex10
My Ride: ZHP, E36 M3
Koni sports w/ OEM ZHP springs
Has anyone run Koni adjustable (yellow) Sport shocks/ struts with the OEM ZHP / Sport package springs?
- Intersested in feedback on this set-up
- Any impact to ride height (believe there should be none)?
- Recommended settings for street application?
Thanks!
l8apex10 is offline   Reply With Quote
Old 04-24-2012, 11:26 AM   #2
Rob43
My Ride: 2003 BMW 331Ci, 5spd
Thanks!
No, I haven't run them with BMW ZHP springs, just on an older race car. But they will work perfectly with those springs when set to the softer settings. You should see NO ride height difference. The Koni Sports are an excellent choice in this application because you can set them on a softer setting to work well with your stock springs. If & when you upgrade to a higher performance spring (higher spring rate) you'll just turn up the damper adjustment to match the new higher performance springs. Buy them, you'll really enjoy them.
Take a look at the most current Koni USA adjustment procedure.
http://www.koni-na.com/adjustment.cfm
Good luck,
Rob.
SUMMIT POINT WV 1:24:229 S.C.C.A.
http://www.vimeo.com/8486878 (Dyno Video)
........add a sh!tload of cowbell.
Old 05-01-2012, 01:48 PM   #3
smolck
My Ride: 2004 ZHP Sedan
Here you go:
Read through the whole thing, there are several updates along the way. IMO, they are EXCELLENT with the ZHP springs.
http://www.bimmerfest.com/forums/sho...d.php?t=608290
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 05-07-2012, 12:03 PM   #4
alpine003
My Ride: BMW
I've ran the OTS Koni Yellows with Sport package springs before on my last sedan and they were indeed excellent. One of the best rides I've experienced on a e46 for all around performance vs. comfort. IIRC, my settings were pretty low like 2f/1r. Turned them up on an Autocross and was amazed on how stiff it could get.
alpine003 is offline   Reply With Quote
koni, shocks, sport, springs, zhp
