Old 02-03-2013, 06:00 PM   #221
cd330
ModZombie Moderator
cd330's Avatar
My Ride: SG E46, AW F30
Marcus, excuses are like a$$holes, everyone's got one and they stink
Just kiddin bud, sucks there won't be a race this year or the drags ...... but understandable
cd330 is offline   Reply With Quote
Old 02-03-2013, 06:01 PM   #222
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I'll be there, but looks like I'm running solo.
Old 02-03-2013, 06:38 PM   #223
mike@maximumpsi
My Ride: 02M3T
Says who?
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 02-03-2013, 07:07 PM   #224
MarcusLSB
Originally Posted by mike@maximumpsi View Post
Says who?
Old 02-04-2013, 12:49 PM   #225
cd330
ModZombie Moderator
cd330's Avatar
Old 02-25-2013, 10:52 PM   #226
SlideFox
My Ride: A Bucket w/ 4-Wheels
What's the latest?
SlideFox is offline   Reply With Quote
Old 02-25-2013, 11:02 PM   #227
MarcusLSB
Originally Posted by SlideFox View Post
What's the latest?
Working on isolating the vibrations causing my flywheel to fall off every 1000mi.
Old 02-26-2013, 09:38 AM   #228
Estoril-E46
My Ride: M3
Not meant to be a solution by any means, but you should definitely safety wire the bolts if you plan on running the car before finding the problem. Just drill each flywheel bolt down the plane of the head. Random google example http://www.mtfca.com/discus/messages/29/48566.html
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 02-26-2013, 11:57 AM   #229
MarcusLSB
Thanks for the tip. I'm having everything balanced individually right now so hopefully something is out of balance and is located. If not its back to chasing the issue.
Old 02-26-2013, 01:38 PM   #230
Twin_Turbo_S54
My Ride: M3
GL.
Everything has a cause, it will definetely be found.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 02-26-2013, 02:08 PM   #231
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Marcus,
Your inbox is full
Old 02-26-2013, 02:09 PM   #232
MarcusLSB
Marcus,
Your inbox is full
Fixed!
Old 02-26-2013, 09:21 PM   #233
95silverM
My Ride: 05' IB M3
good luck finding the culprit Marcus, are you planning on doing ShiftS3ctor or TX2K this year? Can't wait to see this beast tear it up and give M3's a strong title with these upcoming events!
05'IB/Blk M-Cloth 6spd NoSunroof-SOLD
Eurotechniks
EliteEuroCarsLLC.
E46 M3 6-Spd Coupe Roller *WANTED!*
2JZGTE:9.68:1WiscoPistons&ManleyIBeamRods,
GSCS2BilletCams,GSCSprings&TiRetainers,FerreaValves,CustomTurboManifoldw/PTE66mmWG,Pro-EFI,Custom Dash,CAE Shifter,ABCTiltonTripleDisk,E46M3 6-Spd,18x9et31&18x10et.27EC-7's,R888's,WeldedHalfCage&SubframeBrace,& Lots More
B5-S4:BLK/BLK 6-Spd SingleTurbo Shop-Car:In progress..
95silverM is offline   Reply With Quote
Old 02-27-2013, 01:52 AM   #234
MarcusLSB
Probably won't make it to TX2K, but i'm trying to make it to Shift-S3ctor and will definitely make it to MFest!
Old 03-01-2013, 12:07 PM   #235
wanganstyle
My Ride: e36 M3 / E30 GTS1
Let me know if you will be wrenching any weekend this month and I can bring down the final drive setup for you: I'm usually in the southbay on weekends working w team mates on the enduro racer
Sent from my GT-N7100 using Bimmer App
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
