///M3 Forum
Old 04-24-2012, 05:43 PM   #1
B4MC1S
My Ride: 2004 M3 Mystic Blue
Question How does the TPMS on E46 M3 work?
I recently installed new rims. And my TPMS light is going off. I have searched countless post, but it does not answer my question. Are the TPMS for 2004 E46 M3 direct or indirect? Meaning is the sensor installed inside the wheel or is it based of the ABS. Also if it is not indirect, that means I will have to install new sensors on the new rims, right? Any help is appreciated.
Thank you!
B4MC1S is offline   Reply With Quote
Old 01-20-2013, 02:55 PM   #2
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
All years M3 the sensors were based on dsc/abs/wheel speed-spin sensor. This meant that changing your rims (IE getting bigger rims) would change the way the system is reading the wheels.
Any change in rotational speeds and is senses like you got a flat tire.
delmarco is offline   Reply With Quote
Old 01-20-2013, 06:16 PM   #3
wildpig
My Ride: 2003 BMW M3 Convert
Outer diameter of all wheels must match original or else flat tire warnings will trigger.
Now I thought that if you hold down the tire warning button, shouldn't it reset and adapt to the new tire spec?
2003 BMW M3 Convertible
wildpig is offline   Reply With Quote
Old 01-20-2013, 06:48 PM   #4
illestminimike
My Ride: Project Drama
Look up the procedure to reset it. I can't quite remember how it's done. The light will go away. Don't worry.
Old 01-20-2013, 07:28 PM   #5
Alan
Alan's Avatar
My Ride: 2006 M3
1. No
2. No
3. Read you manual.
Alan is offline   Reply With Quote
Old 01-20-2013, 07:34 PM   #6
B4MC1S
I resolved the issue a while back. If you have the RED warning sign, press down the tire warning button to make it go away. But if you want your vehicle to recognize new wheels, press the tire warning button once so it lights up YELLOW. And drive your vehicle around while it's YELLOW and the YELLOW indicator will go away once vehicle recognizes your new setup.
Old 01-20-2013, 07:36 PM   #7
Alan
Alan's Avatar
My Ride: 2006 M3
Thats interesting - but it is not the re-learn new diameters procedure.
Old 01-20-2013, 07:48 PM   #8
B4MC1S
I am not sure of any other methods of re-learning new diameters, but I followed the procedure mentioned in the manual:
