Old 04-26-2012, 10:50 AM   #1
Gabrielrc
My Ride: 325i 2002
M3 diff on non m
Hi, i have a question, does a m3 differential fit on a bmw 320i (i want to do that to have lsd )
Gabriel
Gabrielrc is offline   Reply With Quote
Old 04-26-2012, 10:58 AM   #2
Steven747
My Ride: 05 330ci
yup bolt it right up and the search bar tells you how to do it
Old 04-26-2012, 10:59 AM   #3
Gabrielrc
My Ride: 325i 2002
Thanks!
Old 04-26-2012, 11:45 AM   #4
Steven747
My Ride: 05 330ci
i hope you searched the topic though. the m3 subframe has to be swapped also
Old 04-26-2012, 12:04 PM   #5
Blocked Out
My Ride: Imola 330i M-Sport
The answer is no. M3 diff will not bolt up to the non-M car.
If you wish to have M3 diff in your non-m car you will need to swap M3 diff carrier, trailing arms, sway bar, brakes and e brake. You will also need to shorten your driveshaft in order to accommodate the longer M3 diff
Where in Canada are you? I have all the parts that you'll need for the swap and can help you out with the driveshaft if you need, depending on where you are
Original BMW Teile ///
IMG_1725
Old 04-26-2012, 02:32 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Technically that all bolts up....
Old 04-26-2012, 02:35 PM   #7
Gabrielrc
My Ride: 325i 2002
Do someone done this before ?
Old 04-26-2012, 02:41 PM   #8
aggieE46
Keep it clean
aggieE46's Avatar
There are probably a dozen threads on people doing it.
Old 04-26-2012, 03:38 PM   #9
Steven747
My Ride: 05 330ci
English?
Old 04-26-2012, 04:25 PM   #10
Gabrielrc
My Ride: 325i 2002
Sorry i dont speak english verry well
Old 04-26-2012, 05:10 PM   #11
aggieE46
Keep it clean
aggieE46's Avatar
That's okay, most people on this forum don't.
Old 05-01-2012, 08:57 PM   #12
wrecklessfool
My Ride: is paid off
I just did the swap on a 2005 330i. All you need is the subframe, diff, axles, sway bar and driveshaft (if you currently have a six speed). If you don't have a six speed transmission, you'll likely need a custom length driveshaft.
You DO NOT need the trailing arms, control arms, brakes or e-brake to bolt everything up!! Good luck!
wrecklessfool is offline   Reply With Quote
