Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 04-27-2012, 07:43 PM   #1
JS330
My Ride: '01 330Ci 3 Pedals
DIY Rear Camera input OEM Monitor
Hi Everyone, decided to make this DIY as i had to piece it together from other threads involving dynavins, av inputs and headunit swapping.
Firstly, DO THIS AT YOUR OWN RISK. I TAKE NO RESPONSIBILITY FOR YOUR ACTIONS AND MY ADVICE IS ONLY TAKEN AS ADVICE....NOTHING MORE. Good Luck
So Firstly, the components:
-Av Input harness for factory inputs or if your creative, use the pinout guide Click image for larger version
ID:	448948[IMG] This Harness
- An Ebay Camera
Name:	Screen shot 2012-04-28 at 9.50.47 AM.png
(took me 2 attempts and this is the best so far *required a little dremmeling to get a nice fit
[URL="http://www.ebay.com/itm/150785644470?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649"]This Camera
- Extra electrical wire
- T-20 Socket
So, making sure that your camera is NTSC (unless you have navcoder to change the input) will make this task a lot quicker than my install 4 weeks total due to my stupidity of jumping on a cheap buy
Follow my other DIY of installing the Av Harness Here
Step 1)
Take off the inner boot (trunk) lining
This is a must as you will be routing the av and trigger wire through here.
Step 2)
Removing the boot grab handle with the 4x T-20 screws, gently pull it off.....you might need a little force as 10 years of grime can be quite adhesive
Step 3)
Remove the connector to the boot latch and license plate lights (trick with a tiny flat blade screw driver, wedge it in slightly and twist it up gently to allow it to slide out because the little plastic nub is quite brittle
DO NOT CLOSE YOUR BOOT OR YOUR FVCKED, PUT SOMETHING TO PREVENT IT FROM CLOSING LIKE A TRIPOD I HAD LAYING IN MY BOOT
Fun Part...
Step 4)
Take out the bayonet bulb and pry open, its surrounded by the foam gasket (carefully to retain the top cover which needs to be broke off its melted plastic rivets)
Step 5)
Disconnect the cabling and remove the bracket housing the bulb
Name:	license plate light connectors.JPG
Step 6)
Test fit the camera and dremmel where required to ensure an adequate fit.
Step 7)
Connect the license plate bulb wiring to the new led one on the camera with solder and heat shrink ( there are two ground wires so use a multi meter to find them)
Name:	Solder license.JPG
Step 8)
Cover it back with the top cover and a dab of some super glue to hold the wires in tight
Step 9)
Feed the wires through first before reconnecting the handle grab, including through the little circular whole where the trunk release adn license plate light cable and connector feeds through.
Name:	Av cable and trigger.JPG
Step 10)
Solder with heat shrink the cameras pos and neg to the reverse light on the right hand side of the car as this is near the rubber wire tube. (does not cause bulb out as it requires so little electricity to operate)Click image for larger version
Step 11)
Cut off the av connector plug and feed it with the electrical wire that acts as a trigger down toward the rubber tube.
Name:	Routing the Cables.JPG
Step 12)
Trick with this install is instead of going down through the top of the tube; get a firm blunt wire (rc car antenna is best) and start fondling the rubber tube to make it through the twists and turns of the grommets. Then once it comes through the top, tape the av cable to it first NOT WITH TRIGGER WIRE and gently pull it through, easing the wire through as it could damage the cars wiring if not being gentle.
Step 13)
When av cable is through, tape the trigger wire to the av cable and pull it through gently, one cable first makes it easier as opposed to doing both and causing too much traffic in the rubber tube.
Name:	draping the cables.JPG
Step 14)
Route it through to the other side of the trunk where the tv tuner is, dad and i found that it is easiest to take the wheel spare hatch off and run it along the back where the carpet starts.
Step 15)
Connect up the relay with the trigger wire
from this thread
http://forum.e46fanatics.com/showthr...t=relay+camera
Step 16)
Find a grounding point, dad used the factory ground point of the tuner
Step 17)
Re Install the av plug (Or connect pin out to camera av)Click image for larger version
Name:	soldering av input.JPG
Step 18)
Plug it in to camera input pin or plug
Step 19)
Turn key to on position, not starting the car and put it in reverse gear to see behind you
Name:	finished product.JPG
Put the trunk lining back together and your done, no more reversing over small animals or gnomes.
Originally Posted by DeclanM3 View Post
I hope he isn't using Pirelli condoms..
JS330 is offline   Reply With Quote
Old 04-29-2012, 12:03 AM   #2
PeteAU
My Ride: 330i
Nice one. I donate you an alternative wiring diagram I used. This way you don't need to feed the trigger wire through the rubber grommet at all, since it's available from the NAV unit.
My thread: http://forum.e46fanatics.com/showthread.php?t=898286
BTW is yours really a CCD camera? I ordered one from ebay marked as CCD but it was really just a CMOS. Guy offered me 50% refund
PeteAU is offline   Reply With Quote
Old 04-29-2012, 01:50 AM   #3
JS330
im fairly certain its a ccd, its very clear at night
how do u tell?
Old 04-29-2012, 03:22 AM   #4
PeteAU
My Ride: 330i
how do u tell?
Hard to say, this is how I know mine isn't.
Old 04-30-2012, 03:46 AM   #5
Shonky
My Ride: 2004 E46 M3
You realise you can open the boot with a key even if the wiring is disconnected (or for example the battery is flat)?
Shonky is offline   Reply With Quote
Old 04-30-2012, 05:11 AM   #6
JS330
Nope didn't occur to me, just didn't want to make a stupid mistake in case of the worst
Old 07-05-2012, 12:30 AM   #7
shook
My Ride: E46 328ci
http://www.ebay.com.au/itm/Car-Rever...item4aa622788d
How's that camera look?
shook is offline   Reply With Quote
Old 07-05-2012, 01:19 AM   #8
JS330
Looks alright, just measure the license plate light to make 100% sure
I went through 2 cams before I got the right one haha
Old 10-15-2012, 02:58 AM   #9
deadlysyns
My Ride: 2004 M3
I attempted to install a back up camera based on the TV input white/blue plug. When I pulled the dvd navigation drive, I found a blue/red plug.
deadlysyns is offline   Reply With Quote
Old 10-15-2012, 04:50 AM   #10
JS330
I'm fairly certain you can't achieve a rear camera input without the tv module
I may be wrong but I don't know the Pinout for the red harness
Old 01-22-2013, 02:53 PM   #11
x13atma17x
x13atma17x's Avatar
My Ride: E46 323i & MK6 Jetta
How did you run the cable(s) from the head unit to the trunk?
Just got a D99+ and thinking of adding this rear-cam feature. My concern is where or how will I feed/run the cable to the back.
-omar-
x13atma17x is offline   Reply With Quote
Old 01-22-2013, 04:54 PM   #12
JS330
Mines OEM headunit with television function so I just needed to route the cables to the tv tuner next to the nav drive in the trunk......
you can route the cables however down through the rear seats (pull up the rear seat) and under the carpet to near your handbrake under the center console and through to the rear of the dynavin however
Old 02-10-2013, 07:08 AM   #13
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Nice DIY
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 05-26-2013, 07:34 PM   #14
JS330
-Av Input harness for factory inputs or if your creative, use the pinout guide [IMG] This Harness
- An Ebay Camera
- T-20 Socket
Step 1)
Step 2)
Step 3)
Fun Part...
Step 4)
Step 5)
Step 6)
Step 7)
Step 8)
Step 9)
Step 10)
Step 11)
Step 12)
Step 13)
Step 14)
Step 15)
from this thread
Step 16)
Step 17)
Step 18)
Step 19)
