Old 05-02-2012, 03:56 AM   #1
2002GreenBMW
My Ride: 2001 325xi
Under drive pulley cons?
So my belts are squeaking and I was already planning on upgrading to get a little bit more power out of my m54, I was thinking about the rogue engineering under drive pulleys? My car already had problems with the cooling system, even though I got it fixed I'm wondering if there would be a noticeable difference in the cooling system??
2002GreenBMW is offline   Reply With Quote
Old 05-02-2012, 08:18 AM   #2
Drewfus2101
My Ride: N/A
Take that money you were going to spend on pulleys, and actually fix the cooling system.
Who cares if you pick up a few HP if you get stranded when your car overheats.
Drewfus2101 is offline   Reply With Quote
Old 05-02-2012, 08:22 AM   #3
Snik
Snik's Avatar
My Ride: IR M3 Vert.
ive had em for over 3 years now on a M52TU. no issues at all. No negative side effects. steering was marginally heavier in parking lots, but its not something you'lll remember after 2 days.
A lot of people say you cant notice the difference with em, but i feel like i redline quicker. The day i installed it i hit redline accidentally several times getting on HWYs... after a few hours of driving tho, u quickly adjust.
I have the WP and PS pulleys. i opted not to underdrive the alternator as i have a high wattage stereo system.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 05-02-2012, 02:05 PM   #4
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Agreed / Same.
As long as other things are up to date, like your cooling system; I say go for them. Do understand that in the real world they're worth 3-5 WHP.
Good luck,
Rob.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-02-2012, 02:16 PM   #5
boltan
Banned User
My Ride: 2004 330ci
Agreed, just replaced my pullies and belts the other day and threw in the rogue engineering set while I was in there and it's a nice little upgrade.
Sent from my DROID BIONIC using Bimmer App
boltan is offline   Reply With Quote
Old 05-02-2012, 03:06 PM   #6
2002GreenBMW
My Ride: 2001 325xi
Thanks guys, and to clear it up I already got the ecs cooling system upgrade to fix it.
Old 05-02-2012, 06:54 PM   #7
Blocked Out
My Ride: Imola 330i M-Sport
Rod43,what was that website you always recommend to purchase a set from? They were 150 bucks I think...
Sent from my X10a using Bimmer App
Original BMW Teile ///
IMG_1725
Old 05-02-2012, 07:54 PM   #8
Rob43
Rob43's Avatar
Here's the website, the pulleys on my 330Ci are from them & work perfectly, BUT..................
I've tried to get a hold of KO Performance on several occasions with NO luck, so I'd make sure they're in business before ordering.
http://www.koperformance.com/BMW/eng...ve_pulleys.htm
Rob
Old 05-02-2012, 09:33 PM   #9
Blocked Out
What belt came with them, contitech ?
IMG_1725
Old 05-02-2012, 10:24 PM   #10
trippmann
My Ride: E30
Send a message via AIM to trippmann
anywhere that sells just the ps pump pully? i have the ecs aluminum WP pully and dont want to risk my cars cooling. steering isnt as important.
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 05-02-2012, 10:39 PM   #11
Grande D
My Ride: E36 M3
You could probably contact Rogue and see if they'd sell you the one pulley. Blocked Out I'm guessing you know this based on your general knowledge, but the Continental belts kinda suck... one of mine started squealing with less than 10k miles on it, with a new BMW belt no more noise.
Also: I've observed more people seem to give positive feedback when they buy the Rogue pulleys than others, but really technically there shouldn't be any difference between them I guess- as long as the specs are similar.
It will change your life!
Old 05-02-2012, 10:48 PM   #12
Snik
Snik's Avatar
^ ive ran continental belts for years with no issues.
Old 05-03-2012, 02:36 AM   #13
Rob43
Rob43's Avatar
I don't remember, I'm currently on vacation so I can't check.
Rob
Old 05-03-2012, 12:36 PM   #14
boostedmanifold
My Ride: e46 m3
TMS pulleys, no negatives. No noticable increase in performance.
boostedmanifold is offline   Reply With Quote
Old 05-04-2012, 09:39 PM   #15
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
I have used UUC pulleys I picked up locally for a good price. Didn't really notice a difference, but every little bit helps on my 325 I guess. UUC was nice enough to email me the belt size I needed too, which I picked up at Advanced Auto. I def wouldn't have spent $200+ new on them though, for the gains it really isn't worth it in my opinion.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 05-04-2012, 09:42 PM   #16
Snik
Snik's Avatar
bought mine used from Yellowman years ago, he thru in a brand new belt. still going.
Old 05-10-2012, 01:20 PM   #17
325iZCW
My Ride: 2003 325i (sluhbox)
See my last thread!
Any idiot with a foot can do 100 mph in a straight line. A good driver can do different speeds on squiggly lines.
325iZCW is offline   Reply With Quote
Old 05-10-2012, 05:48 PM   #18
johnrando
My Ride: '06 330 CIC ZHP
I dropped one MPG when I went with my pulleys. Other than that, no cons that I know of. I can't really tell the difference but it "seems" to pull easier with the pulleys.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
