Old 05-04-2012, 09:51 AM   #1
TwiztedTD
My Ride: 2000 328i
HID fog light conversion for e46
I have a 2000 328i sedan and want to switch the fogs to hid. What do people suggest buying? I'm also looking for something easy to install I'm not good mechanically.
Thanks in advance!
Sent from my HTC-X710a using Bimmer App
TwiztedTD is offline   Reply With Quote
Old 05-04-2012, 12:11 PM   #2
sunsetcoast
My Ride: '99 323i & '00 323iT
If you don't already have HID low beams, you will get much bigger return on your investment/effort by doing that upgrade. After upgrading to HID, I have found very little use for the fog lights for vision (and I live by a very large lake which causes lots of fog).
Fogs require a very low beam with a sharp cut off. This typically means a projector-type housing. The generally rectangular housing in the pre-facelift models are not projectors, so nothing is plug-n-play.
If you want "whiter" light, consider replacing the bulbs with SilverStar Ultras or similar products.
sunsetcoast is offline   Reply With Quote
Old 05-04-2012, 12:16 PM   #3
trizzuth
My Ride: 231k, 16yr old B3AST
Just to let you know, I did the HID retrofit into my 2001 330i non-sport fogs. They worked fine for about 2-3 hours then one went out, then the other, and I blew a fuse. I replaced the fuse and it blew out again quickly, so I just ended up ripping them out and using some 3000K halogen bulbs so they are yellow and cut through the fog better..
trizzuth is offline   Reply With Quote
Old 05-04-2012, 12:24 PM   #4
Adamo99
My Ride: 2016 Wrangler 75thAE
I did an HID retrofit into '04 330Ci vert fog lights, with DDM 50W ballasts, 5000K bulbs, and they have been working flawlessly for the past four years.
Adamo99 is offline   Reply With Quote
Old 05-04-2012, 12:48 PM   #5
DHK
My Ride: 2002 BMW 325Ci
My previous Owner did this on my 02 325Ci. It is nice, but I mostly think its nice because it makes the fogs match my Xenon low beams.
DHK is offline   Reply With Quote
Old 05-04-2012, 02:21 PM   #6
My Ride: Lexus
There's no simple plug and play option. You have to retrofit proper projectors (sharp cutoff, evenly distributed projecttion (no hot spots) into OE or aftermarket halogen foglight housings. In other words, it will take some modification, drilling, cutting, gluing. Anything else is ghetto and dangerous. (i.e., buying ebay projector foglights and slapping a $20 chinese kit on them)
Gotta spend at least $200-300 for a decent setup
Old 02-05-2013, 10:32 AM   #7
Redline
Redline's Avatar
My Ride: ///M3 Vert
I have oem e46 m3 hid fogs from my friends m3 that I want to install in my mtech II bumper.
My car is non xenon and came with no fog lights, what would I need to wire them up? If possible...
k.
///M
Old 02-05-2013, 11:38 PM   #8
DonaldE
My Ride: 2002 330i
Thanks in advance!
I think this rules out your suggestion
DonaldE is offline   Reply With Quote
Old 02-05-2013, 11:38 PM   #9
DonaldE
My Ride: 2002 330i
Just get a good set of bulbs if you want something easy
And no, no HID kit is going to be a good set of bulbs
