Old 05-07-2012, 04:31 PM   #1
HiHoBrian
My Ride: 05 M3
Install UUC clutch or not?
I recently got a good deal on a UUC lightweight E46 M3 flywheel with the M5 clutch assy. I have normal mods like headers,intake,wheels ect. My car is an 05 with 60k miles on it and I have no issues with the current clutch at all. I drive like a typical E46Fanatic with a modded M3 and plan on doing a two or three Auto X events,and maybe one track day at Poccono sometime. FI is a possiblity in the future. All my maint is up to date. Is this clutch an upgrade worth doing,or could it become more headaches than a person needs?
HiHoBrian is offline   Reply With Quote
Old 05-07-2012, 08:03 PM   #2
Steven747
My Ride: 05 330ci
won't be any headaches expect for your left foot. i would say wait tell your stock burns out or you can burn through your current clutch and have some real fun while your doing it then just put in the uuc
Old 05-08-2012, 09:25 AM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Great mod. Do it.
Old 05-08-2012, 09:03 PM   #4
HiHoBrian
My Ride: 05 M3
There are a few members on a different forum that really are against the uuc clutch. They mostly tied thier claims in with poor customer service. Although I havent seen any actual evidence either good or bad about the part itself. I would like to hear from someone that has this setup now if possible.
Old 05-09-2012, 09:11 AM   #5
aggieE46
Keep it clean
aggieE46's Avatar
I have the setup on my 330. I love it. One of my favorite mods.
You're going to get noise with just about any LTW flywheel. If a little gear lash is going to bother you, don't do it.
It feels like you pulled a couple hundred pounds off your car for lower gears. Revs feel good.
Old 05-09-2012, 10:39 AM   #6
HiHoBrian
My Ride: 05 M3
My exhaust is probably loud enough to drown some chatter out. Looks like I'm going to install it. Thanks.
Old 05-10-2012, 01:19 AM   #7
DarkJoker
My Ride: 01 330ci
^chatter is at idle
i still hear it running straight pipes
i also have the uuc setup in my car 330ci
and i dont think its a leg killer by any means
if i could change anything about every bmw
it would be the pressure engagement
its to soft with no push back on pedal return
i was hoping with that setup it would be a harder pedal to push but to me it is not
i also have done the mason engineering "short shift pedal"
to help it and it did in a minor form
my next experiment is changing out the return spring to see if i can get the desired feel i want
DarkJoker is offline   Reply With Quote
Old 05-10-2012, 08:03 AM   #8
poopfacekillah
My Ride: 11 X5 35D, 02 330XI
I did a stage 2 CNS racing clutch in my old M and wanted to kill myself during the break in period. It was like an on/off switch. Made me want to sell the car... so I did.
poopfacekillah is offline   Reply With Quote
Old 05-10-2012, 08:19 AM   #9
TxZHP04
My Ride: ESS TS2+ ZHP
How does this have anything to do with the subject of this thread which was looking for feedback on UUC clutches?
Old 05-10-2012, 09:34 AM   #10
HiHoBrian
My Ride: 05 M3
I would sell my body to John Travolta before I would ever sell my car due to a mod that can be corrected.
Old 05-10-2012, 10:00 AM   #11
poopfacekillah
Well, doesnt UUC make different levels/stages? I looked at them when I was looking at doing the clutch. I was just advising to not go too high of a performance clutch without taking into account what else is affected.
Old 05-10-2012, 10:01 AM   #12
poopfacekillah
No? But would you sell an 05 TDI passat and an e39 M5 so you could buy a 2011 X5 35D? 'cause that is what I did.
Old 05-10-2012, 10:10 AM   #13
HiHoBrian
My Ride: 05 M3
Not where I am in life. Tdi has extreme fuel milage potential,e39 m5 is awesome,but getting a little old by now. I live on my own with no kids. X5 would just be a glorified station wagon for me. I don't even have enough friends to justify having something that big.
Old 05-10-2012, 10:12 AM   #14
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
Passat? Yes!
E39 M5?
You must be outside of your mind, unless you needed a tow vehicle for a track toy.
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 05-10-2012, 10:20 AM   #15
poopfacekillah
Yeah, I'm not trying to thread jack, but I needed a vehicle with cargo space for the dogs. The M was in great shape for a 2002, but combination factors (only a single car garage, DC traffic blows cats, and I like to switch up my vehicles rather frequently) dictated that it was time to go. If i can ever sell my stupid house then I will get another M, but it will be an F10. My toy hauler is an 03 Ram 2500 Cummins and 18ft trailer.
Old 05-10-2012, 10:51 AM   #16
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
yes do it
the flywheel and clutch are very close to each other if you only do one of them its going to cost you money again to get to the clutch most people change both things at once to save money in the long run of things...
bob
bobm3 is offline   Reply With Quote
Old 05-10-2012, 10:58 AM   #17
HiHoBrian
My Ride: 05 M3
And also back on topic,if you bought an m5 clutch for your m5 and engagement was on/off then possibly you got the wrong compund,or an overly agressive pressure plate. That is what I am looking to confirm with this specific Uuc clutch. Mine is organic compound so I think I am all set.
Old 05-10-2012, 11:03 AM   #18
DarkJoker
My Ride: 01 330ci
Thats the same setup i have
Performance organic
Its a close to stock feel
But theres a difference between stock and the uuc stage 2
Sent from my EVO using Bimmer App
