Old 05-08-2012, 09:43 AM   #1
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Oil pressure at idle below 7 PSI
Would oil pressure drop if a heavier weight oil is used?
I've been using 0w30 for 30k miles and noticed that consumption was going up. I'm usually down 1.5-2 quarts of oil after 4500 miles.
So I decided to add a heavier weight oil at 5w30.
My oil pressure for 0w30 is at 7 psi while my oil pressure for 5w30 is at 5 psi at idle.
Normal?
phamine is offline   Reply With Quote
