Old 05-08-2012, 01:12 PM   #1
SoloII///M
My Ride: Many
M54 / MS43 with cable throttle?
Hey guys,
Any idea if it's possible to convert the M54 with MS43 DME to a cable-actuated throttle body? Will the throttle body from, say, a '95 M3 bolt up or is it a completely different size / bolt pattern?
I know some E46s had throttle cables but were still drive-by-wire throttle bodies - not interested in that. I want a direct link between my foot and the throttle body. Just curious if it's been done.
John V
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 05-08-2012, 04:08 PM   #2
bryce-o
My Ride: 2013 335is 6mt
there's a lot more to just changing out the throttle body hardware. the ecu tune/logic, dsc, etc. is all based on the dbw throttle.
i would venture to say that it's not worth the coding, tuning, custom fabrication, etc. that would be required to implement it.
bryce-o is offline   Reply With Quote
Old 05-08-2012, 04:51 PM   #3
SoloII///M
My Ride: Many
It may not be worth it to you, but it is certainly worth it to me.
I think ultimately this will be something I solve with a Megasquirt, but I'm not there yet so I was hoping for an interim solution.
John V
Old 05-08-2012, 05:51 PM   #4
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
it has been done, there is someone on this forum who is running an e30 m54b30 swap and he is running MS3 with a throttle cable. i think his name is hoveringguy or something like that.
SL Blak Soldier is offline   Reply With Quote
Old 05-08-2012, 07:46 PM   #5
Hornung418
My Ride: '04 MB ZHP
It's Hoveringuy. His name is Steve. His is a custom 3.5" cable driven TB using the M20 gas pedal.
FWIW, The M52tu is cable driven. The electronics are for the throttle position sensor and the cruise control. I move the pedal and the valve opens in sync. It is no different than an e36 throttle body.
Hornung418 is offline   Reply With Quote
