Old 05-08-2012, 02:04 PM   #1
BMW330CiEric
My Ride: 2004 BMW 330Ci
How long for computer to reset??
I have an 04 330ci that had the computer reset, the check engine light was on. I tried to have it smogged but it came up as incomplete. How many miles do I need to drive it before the computer comes up as complete. I've driven it 90 miles. Thanks for any help
BMW330CiEric is offline   Reply With Quote
Old 05-08-2012, 02:05 PM   #2
My Ride: Lexus
I have absolutely no idea what you're talking about.
Old 05-08-2012, 02:07 PM   #3
BMW330CiEric
Why did you respond then????
Old 05-08-2012, 02:15 PM   #4
My Ride: Lexus
So you can clarify. Don't go down this road with me. I'm trying to help you. Trust me
Old 05-08-2012, 02:17 PM   #5
My Ride: Lexus
Nice ninja edit, btw. You clarified your post just a little right before responding to my post to make it look like my comment wasn't justified. I should've quoted.
Old 05-08-2012, 02:19 PM   #6
Redryan98
My Ride: 07 Legacy GT 5MT
I think he's referencing how long before the car will throw a CEL after having it cleared without actually fixing the source of the CEL. This might be completely wrong but I thought it was based off of warm up cycles, not a specific number of miles. Start/stop a few times over a day or two, but most likely the code will come back. Did you check what the code was actually for?
Redryan98 is offline   Reply With Quote
Old 05-08-2012, 02:20 PM   #7
Rice4bfast
My Ride: 325XiT 5MT
OP, happened to me the other week and it seems that you have to drive a few hundred miles for everything to collect data or use the following method:
Evap not ready
I got scared when i failed cos i thought i bought a lemon but i realized that i just cleared code and this is what the DME did... hope that helps good luck!
Rice4bfast is offline   Reply With Quote
Old 05-08-2012, 02:24 PM   #8
My Ride: Lexus
Yeah thats what I thought after he clarified his post. His first post read something like HALP TRIED TO SMOG CAR COMPUTER WAS RESET AND FAILED. HOW LONG BEFORE COMPUTER IS COMPLETE?
Fix your problems correctly. Don't cheat the system.
Old 05-08-2012, 02:34 PM   #9
BMW330CiEric
I fixed the problem that caused the CEL to come on. I was told I need to drive the car for 40-50 miles before I took the car in for a smog check. I have driven the car 90 miles and some of the functions are still coming up as incomplete.
Old 05-08-2012, 02:37 PM   #10
trj
My Ride: 325Ci
It is called the driving cycle I believe.
Read up on driving cycles, someone had this issue recently here and a very detailed information was given there.
If you follow that thread you will know how many engine start ups you need and how many miles between them.
Old 05-08-2012, 02:40 PM   #11
Tavo
My Ride: 318i
After you clear the computer you need to drive up to 100 miles to give it a chance to monitor all the sensors and register the results. Sometimes it may be complete in about 50 miles. You'll know when you connect the scanner and check the status. It tells you if ready or not ready. Wait till you see everything ready before going for an inspection.
Tavo is offline   Reply With Quote
Old 05-08-2012, 02:42 PM   #12
jcns
My Ride: California
not sure what kind of 90 miles you did, but you have to do mixed driving. City, highway, stop and go.
jcns is offline   Reply With Quote
Old 05-08-2012, 02:44 PM   #13
BMW330CiEric
Thanks. I just found this...kind of discouraging.
"I had a friend with this problem on his 330i. Did drive cycle after drive cycle nothing worked and nothing was wrong with his car. Finally after he drove around 900 miles or so his readiness codes were ready."
Old 05-08-2012, 02:51 PM   #14
trj
My Ride: 325Ci
900 miles That would be bonkers to drive that much to complete a drive cycle.
Anyway this post might help you.
This post has it all condensed.
http://forum.e46fanatics.com/showpos...26&postcount=1
Old 05-08-2012, 02:56 PM   #15
My Ride: Lexus
OK you fixed your problem. In the future, begin your posts with as much information as possible.
Old 05-08-2012, 02:59 PM   #16
BMW330CiEric
Good stuff. How do you do this in SoCal...
"My check engine light came on. Not wanting to get screwed on the repair I bought a Peake Tool. By the time the tool arrived the light had gone out. Plugging the tool in showed a code for the O2 sensor. I cleared the code. About a week later took the car in for NYS inspection. Failed inspection due to catalyst not ready and O2 sensor heater not ready. This is a function of the OBD II diagnostic not having enough drive time to set the sensor.
A Google search for for "BMW OBD 2 Drive Cycle" tells all you need to know about the drive cycle. A "drive cycle" which is begun with a cold start. Speeds over 60 mph or RPM over 3000 interrupt the cycle.
My research showed that I had to do two things, drive between 50-60 mph 15 minutes. This is easy to do, just keep the revs down. Of note though, driving 57 mph on the Southern State, EVERYONE passes you.
The other requirement was to drive between 20-30 mph for approx 4 minutes. In my neighborhood on Long Island this is very hard to do. I don't think you can drive for more than one minute without having to stop for a stop sign or a light. In 3 or 4 days of trying I could not do this. Finally pulled out of work right onto the LIE service road, flashers on in the right lane.
A couple of days later, inspection passed!"
Old 05-08-2012, 03:40 PM   #17
trj
My Ride: 325Ci
Now you know.
Old 05-08-2012, 04:12 PM   #18
maurer
My Ride: 04 Coupe
I thought it took 4 drive cycles to turn a engine light on.....Luckily I live in FL where there are no smog emissions
maurer is offline   Reply With Quote
Old 05-08-2012, 05:41 PM   #19
haurelio
My Ride: 2001 bmw 325i
they usually recommend to drive the car for at least 70 miles before taking the car to DMV
Old 05-08-2012, 05:58 PM   #20
Jesse M
My Ride: 05' ZHP
When I was a valet at Nissan the techs would disconnect the battery for completing certain services, and I had to go drive around for a half hour for the ecu to reset. I don't exactly know about bmws but I can't see it being any more than a half hour/30-40 miles. Miss that job ..
Jesse M is offline   Reply With Quote
