Sponsored by BAVSOUND
Old 06-16-2003, 11:19 PM   #1
TDing525i
My Ride: 2002 BMW 525i
I need help with wiring subs to an amp
My friend's got a mono channel amp that he's pairing up with two 4-ohm single voice coil subs. Can I wire them to 2-ohms or does it have to be 4-ohms? Whichever one it is, could someone please draw a rough sketch of what the wiring would look like using Paint or something?
Here's the type of sketch I'm talkin about. I am almost positive that that's what it looks like. The only thing I can't remember for sure is if the amp has 1 or 2 sets of +/-. I would assume that since it's a mono that there's only one??
TDing525i is offline   Reply With Quote
Old 06-17-2003, 11:57 AM   #2
Temonio
My Ride: 2001 BMW 325i
It all depends on what amp you have. It's stable at a 2ohm load and your subs are DVC then I'd go with the 2ohm load. (Usually subs and amps run higher RMS at 2ohms) If not, the you can hook the mono amp with the two 4ohm subs...It just wont hit as hard.
Me and my heart
Temonio is offline   Reply With Quote
Old 06-17-2003, 12:19 PM   #3
millst
My Ride: BMW 330i
Like Temonio said, if the amp is 2-ohm stable then wire the subs in parallel. Otherwise, you'd have to go series to use both.
Series
Like batteries in a flashlight. Connect a wire from amp + speaker + and another wire from amp - to the other speaker -. Then connect the two speakers using the unused + and - with a wire.
Parallel
Use two sets of wires. Go from amp + to speaker 1 + and amp + to speaker 2 + with a different wire. Do the same with the negative.
If those are DVC subs, then things can get a little trickier.
millst is offline   Reply With Quote
Old 06-17-2003, 01:41 PM   #4
Hota
My Ride: 2002 E46 M3
Note that if you wire in series, you'll have a total resistance of 8 Ohms.
E46 M3 Ti Silver/Imola
Created 18 June 2002
Hota is offline   Reply With Quote
Old 06-17-2003, 02:18 PM   #5
TDing525i
they are not dual voice coil. i'd like to be able to wire it to 2 ohms. subs are each 10" visonik 250W, 500W peak. amp is a bazooka el1500 500Wx1.
Could someone please take my little sketch and just draw in the wiring sceme?
Old 06-17-2003, 03:33 PM   #6
TDing525i
Edit: I just need a little more clarification with the parallel wiring. I'm getting confused because the amp has only one + and one -
Old 06-17-2003, 03:44 PM   #7
TDing525i
Is this how you do it? If so, what do I use to connect the wires of the speakers together?
Old 06-17-2003, 03:59 PM   #8
millst
My Ride: BMW 330i
Your diagram is mostly right. Just twist the ends of your two positive wires together and plug those into the positive terminal of your amp. Do the same for the negative.
tm
Old 06-17-2003, 04:40 PM   #9
TDing525i
Gotchya. Thanks a lot!
Old 06-18-2003, 12:30 AM   #10
ken330i
E46 Fever God
My Ride: F2 dumped
Send a message via AIM to ken330i
what are the disadvantage and advantage of series vs parallel?
i'm trying to understand this by heart.
ken330i is offline   Reply With Quote
Old 06-20-2003, 12:57 PM   #11
millst
My Ride: BMW 330i
Series has more resistance so you get less current and power. This will keep your amp cool. However, parallel will give you more power, a lot more. 2 ohm to 8 ohm is a big difference. Read up on Ohm's Law and all that good stuff.
Old 06-20-2003, 02:16 PM   #12
SrCsTc
Banned
My Ride: 00 323Ci
Send a message via AIM to SrCsTc
You can't get a 2ohm load from two 4ohm DVCs. If they're SVCs then you'e set. Most amps can handle a 2 ohm load.
Rich
SrCsTc is offline   Reply With Quote
Old 06-20-2003, 03:51 PM   #13
millst
My Ride: BMW 330i
I checked and it'll handle 2 ohm fine, so wire them in parallel. If that amp is overrated, then you might actually want a better one since the speakers can handle 250 RMS.
tm
Old 06-20-2003, 06:48 PM   #14
TDing525i
Correct.
I wired them in parallel and they work great.
Old 06-20-2003, 06:55 PM   #15
SrCsTc
Banned
My Ride: 00 323Ci
There's a good Tutorial here on Wiring your subs
Old 06-23-2003, 09:08 AM   #16
Temonio
I reread my post and confused my own damn self! Good Catch fellas!
Me and my heart
Old 06-23-2003, 12:42 PM   #17
ken330i
E46 Fever God
My Ride: F2 dumped
first off, thank you for responding to my questions. i'm cleared now, but not sure about how you come up with 2 and 8 ohms.
so, PARALLEL for 1 channel amp, 4 ohms single voice coil sub would be R(t) = 1/R(1) + 1/R(2) = 2 ohms (4 ohms divided by 2 speakers).
and, SERIES for 1 channel amp, 4 ohms single voice coil sub would be R(t) = R(1) + R(2) = 2 ohms. i know how you get 8 ohms. that's by adding 4 ohms + 4 ohms = 8 ohms. i thought this is only true when you have dual voice coils on each sub? maybe my formula is wrong? i m confused. please educate me. thanks.
R = Resistance of one voice coil
R(1) = Resistance of the first single voice coil, R(2) = ...2nd, etc.
R(t) = total Resistance
