Old 05-08-2012, 09:44 PM   #1
DKTim
My Ride: 2000 323i 5MT
My diff only took 1 liter of fluid?!
2000 323i 5speed 170,000km
Today I did spark plugs (NGK) and Diff Fluid (Redline) and threw in a magnaflow resonator.
Here is an album
http://imgur.com/a/GsEBT
The Diff Fluid:
I drained the fluid, only about 1 liter came out, there was no metal shavings, but the fluid was dark. It was still very clean, but dark. When I filled the diff back up I was only able to fit one liter (one bottle) before it started coming back out. My car was not perfectly level. The rear end was a couple of inches higher than the front end. So theoretically I might have overfilled it, but I was only about to fit one liter in. I drove the car for about 20km without issue.
My repair manual says I should be able to fit 1.73 liters.
The pictures will show you exactly how much came out...
Should I be worried?
Also I took some other random pics of my car, and noticed a power steering fluid leak which I will work on soon.
DKTim is offline   Reply With Quote
Old 05-08-2012, 10:23 PM   #2
DKTim
anyone?
Old 05-08-2012, 10:45 PM   #3
Alex323Ci
My Ride: M3 & 323Ci (sold)
that's about right. people often buy two quarts so they can use a hand pump on the bottle neck to fill up. so one is left with a little in the first bottle(because you can't get it all out) then swapped over to the 2nd bottle to fill the rest of the way.
Old 05-09-2012, 11:44 AM   #4
DKTim
The repair manual states 1.73L that is what is freaking me out.
Old 05-09-2012, 11:59 AM   #5
kd7iwp
My Ride: 2001 325i
I used about 1.5 L in my differential on a 2001 325i 5 speed. You've got the car completely level, the rear-end isn't higher than the front?
kd7iwp is offline   Reply With Quote
Old 05-09-2012, 12:25 PM   #6
ChicagoRY
My Ride: 2002 E46
Here is an album
The Diff Fluid:
First - it's a diff, not an engine that goes through a combustion process - so unless there is a leak of the fluid you shouldn't be depleting fluid over time. It's not going to evaporate. So what you take out, should be what you put in. If there is a big discrepancy, you probably have a leak.
And I think it's normal for fluids used for lubrication of metal to turn brownish over time. Occasionally someone that has a lot of experience can smell a problem with engine oil (i.e. coolant in it) but, those skills aren't necessary for DIY, mainly just party tricks.
And I think your service manual is incorrect or you're looking at the wrong fluid. This is what my Bentley says:
PS - listed "capacity" will always be a little more than what you can actually fill it with, since there will always be some left in whatever you're draining (still adhering to metal, etc.).
hth
ChicagoRY is offline   Reply With Quote
Old 05-09-2012, 02:21 PM   #7
lab rat
My Ride: '02 330iT
Your manual is wrong. About 1L is normal.
Because sleeper
Old 05-09-2012, 07:51 PM   #8
DKTim
I used a haynes manual, and it states 1.73. Darn, I shouldn't have cheaped out on the manual ahah.
maybe 1.73 is the total displacement of the differential housing.
Old 05-09-2012, 07:54 PM   #9
SD 328I
My Ride: S197, E90, and 1125R
Mine was 1.0L, but you never get it all out unless you remove the differential cover completely.
If you fill to the point it's dripping out of the fill hole, then you are fine.
SD 328I is offline   Reply With Quote
Old 05-09-2012, 08:00 PM   #10
ChicagoRY
My Ride: 2002 E46
Ya you're right, I have the Haynes too and it does say 1.73.
Speaking of service manuals, am I the only person that would pay double if the photos were in color?
And man would I love for these to be on the ipad or kindle some day, that would be handy. I hate having my whole laptop in the garage.
diff, differential, redline, spark plugs
