Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > eBay / craigslist
eBay / craigslist
Found an interesting auction on ebay or listing on craigslist that other fanatics may be interested in? Post it here!
Old 05-09-2012, 12:05 AM   #1
jaydc393
My Ride: 04 M3 Vert
Send a message via ICQ to jaydc393 Send a message via AIM to jaydc393 Send a message via Skype™ to jaydc393
ViewSonic Projector PJ402D - Home Movie Theatre - $300
http://losangeles.craigslist.org/lac...998693091.html
http://novatechgadgets.com/viewpj402d.html
Refurbished: $533 online
New: $833
NOW ONLY $300!! PRICE LOWERED
My current Bulb is fairly new, Less than 20 Hours of use.
Great Condition, No Damage or Scratches
Carrying Case, 10 Ft VGA Cable Included
Features and Benefits
Retail
Bright in virtually any setting with 2,000 lumens Packs 2,000 lumens in just 4.6 lbs. It's the bright choice for mobile presenters.
DLP� Technology Stunning all digital clarity delivers lifelike color, sharp graphics, and outstanding video.
Ultimate video source flexibility Connect a computer or add a video source for dynamic meetings and presentations.
Supports HD signals including 720p and 1080i Capable of displaying HDTV signals as well as other video and data sources*.
Advanced video features Motion adaptive deinterlacer for superior video performance.
Whisper-mode extends lamp life Extend the life of your lamp up to 4,000 hours** and reduce noise output.
OnView� controls for superior screen adjustablility Screen geometry and color adjustments are precisely made via an easy-to-use, on-screen menu.
Specifications
PROJECTOR Type 0.55" DDR DMD, DLP� Pixel Format 800x600 SVGA Lens Manual zoom, manual focus Zoom Factor 1.2 Keystone Vertical � 15�
DISPLAY Size 27.8"-277.8" (diagonally) Throw Distance 47.3"-393.6" Throw Ratio 1.79-2.1:1 Lamp 200W, 2,000 hours** Brightness 2,000 ANSI lumens Contrast Ratio 2000:1 Aspect Ratio 4:3 (native), 16:9
AUDIO Speakers 1x2 watts
INPUT SIGNAL Frequency Fh: 3179kHz; Fv: 5085Hz Computer/Video NTSC M, NTSC 4.43, PAL, SECAM, HDTV (480i, 480p, 576i, 576p, 720p, 1080i)
COMPATIBILITY PC Analog: from VGA up to SXGA (scaled) Mac�+ Analog: up to SXGA (may require a Mac adapter)
CONNECTOR RGB Input 15-pin HD, D-sub (x1) Composite Video Input RCA jack (x1) Component Video Input VGA DB-15 to HDTV/component cable* S-Video Input Mini-DIN 4-pin (x1) Audio Input Stereo mini-jack (x1); RCA (L/R)
POWER Voltage 100-240 VAC, 50/60Hz (universal) Consumption 250W (typ)
CONTROLS Basic Standby/On, input, menu v OnView� Display mode, brightness, contrast, keystone, aspect ratio, blank screen, gamma, white peaking, color temperature, user color, video (sharpness, saturation, tint), display (phase, tracking, H. position, V. position), advance (auto source select, rear, ceiling, eco mode, lamp hours, lamp reset, auto shutdown, OSD timeout, menu position, factory reset), audio (audio, mute)
NOISE LEVEL Normal 36 dB (typ) Whisper mode 34 dB (typ)
DIMENSIONS (WXDXH) Physical (mm) 256mm x 88mm x 200mm Physical (in.) 10" x 3.8" x 7.9"
WEIGHT Net 4.6 lb. (2.1 kg) Gross 11.0 lb. (5.0 kg)
OTHER Vertical digital keystone correction, 3:2 pull down, whisper mode
PACKAGE CONTENTS Projector, power cords, VGA cable, RCA video cable, S-video cable, audio mini-cable, remote control, soft case, lens cap, ViewSonic Wizard CD, Quick Start Guide
http://www.projectorcentral.com/ViewSonic-PJ402D.htm
jaydc393 is offline   Reply With Quote
projector
