Old 05-11-2012, 05:41 PM   #1
Locutus09
My Ride: Something Slow
Blackstone Oil Report: Cause for Concern?
Report shows some extra metal that is usually contributed to rod bearings. My temperatures do rise alittle ONLY when I'm autocrossing. Immediately after the temps fall under 210F again and never get above that during DD. As well, anything that can explain the gas?
Thoughts?
Locutus09 is offline   Reply With Quote
Old 05-12-2012, 11:51 AM   #2
SoloII///M
My Ride: Many
Did you take the sample after the engine had only run for a few minutes, or do you do a lot of short trips? That would explain the gas.
As for the lead and iron, it seems to be reasonably common with the S54.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
