Old 05-11-2012, 05:08 PM   #1
NaZty NaZe One!
My Ride: 02' 330ci "Ebony"
Send a message via AIM to NaZty NaZe One!
3.64 or 3.91?? which to go with
hey everyone. im looking to change out my stock diff from my 02 33oci for a quicker more responsive differential. i read up on kpengs diff swap and like the improvements, however im still a little hesitant.
can i have some opinions on which to get the 3.64 or the 3.91. is the labor needed to install them the same (e.g., the 3.91 needing the longer drive shaft, etc)?
thanks in advance!
Photobucket
NaZty NaZe One! is offline   Reply With Quote
Old 05-11-2012, 05:17 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
I'm running a 3.64 with a 6-spd and 7k rpm rev limit and can't imagine wanting to go any shorter. Don't know the specifics of your car but I can't imagine running either with a 5-spd and 6500 rpm rev limit. Most people don't go any shorter than a 3.46. This is all assuming a manual transmission, if you have an auto then things might be a little different.
Old 05-11-2012, 05:28 PM   #3
NaZty NaZe One!
yep its an auto. also your setup is far superior to mine in that you have a super charger and LSD. that correct?
Photobucket
Old 05-11-2012, 05:53 PM   #4
TxZHP04
I know the autos have taller transmission gearing so my previous comments are largely irrelevant. Looking at all the ratios, I think I might opt for the 3.91 myself as this is the same setup as the X3 2.5i. Maybe others will chime in. Since this diff came with the X3 2.5i auto, I imagine it should be a direct swap.
Old 05-11-2012, 06:50 PM   #5
Sknutson913
My Ride: 01 325i
Subscribed. OP do you have a link to the did swap discussed in the opening post. I just picked up a 01 325i and it definitely needs to wake up!
Sknutson913 is offline   Reply With Quote
Old 05-11-2012, 09:45 PM   #6
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
With the auto I'd say 3.91 for sure!
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 05-11-2012, 11:55 PM   #7
Steven747
My Ride: 05 330ci
op i think you have a 3.38 diff i have a 3.46 diff and a guy to do the labor. if your interested in a slight boost we can do the swap and you pay for my labor on my end shouldn't be that steep at all
Old 05-12-2012, 12:25 AM   #8
KickTheCAN
My Ride: United States
Didn't most autos come with 3.46?
Anyways, go with the 3.91 ratio. I think Kpeng's opinion is worth more than most...as that's what I am planning to do.
6000k Angel Eyes, Morimoto Mini retrofitted, Active Autowerke Exhaust, Cooling system refresh, ST V1 coilovers, Electric fan swap, 95,000 miles
KickTheCAN is offline   Reply With Quote
Old 05-12-2012, 12:38 AM   #9
Steven747
My Ride: 05 330ci
i think auto 330's are 3.38
Old 05-12-2012, 01:44 AM   #10
NaZty NaZe One!
Stock 3.38.
Photobucket
Old 05-12-2012, 01:44 AM   #11
NaZty NaZe One!
The zhp's come with 3.64
Photobucket
Old 05-12-2012, 08:05 AM   #12
Steven747
My Ride: 05 330ci
interested in a 3.46 or not aggressive enough plus u r in socal ?
Old 05-12-2012, 10:51 AM   #13
TxZHP04
3.38 to 3.46 is a completely worthless swap.
Old 05-12-2012, 02:23 PM   #14
NaZty NaZe One!
3.46 is a bit low Steven. Thanks anyways.
Photobucket
Old 05-13-2012, 11:14 PM   #15
NaZty NaZe One!
Any more suggestions?
Photobucket
Old 05-14-2012, 01:04 AM   #16
daniel_f.
My Ride: 330iC
Do you have the ZF or GM tranny? If ZF, try to get the 3,91 from a x3 2,5 !MANUAL! as its 188k. the 3,91 from a x3 2.5 with auto is just 168k and therefore not engineered to withstand the torque.
you could buy a drive shaft from a 2.5 3series or change the input flange. just count the revolutions the input flange was tightened, change the flange and retighten it.
Old 05-14-2012, 10:58 AM   #17
Steven747
My Ride: 05 330ci
your gunna have a pretty bad mpg number lol
Old 05-15-2012, 01:49 AM   #18
NaZty NaZe One!
How can I find out what bran the tranny is?
Photobucket
Old 05-15-2012, 02:01 AM   #19
daniel_f.
My Ride: 330iC
Inpa or under the car at the tranny itself
Old 05-15-2012, 04:49 AM   #20
TerraPhantm
My Ride: M3 & ZHP
Why would ZF vs GM make a difference anyway?
