Old 05-15-2012, 11:16 AM   #21
daniel_f.
My Ride: 330iC
GM with 3,91:1
doesnŽt look good in second?!
Old 05-15-2012, 10:19 PM   #22
TerraPhantm
My Ride: M3 & ZHP
Originally Posted by daniel_f. View Post
GM with 3,91:1
If it could handle a 3.67:1 gear (1st gear in the ZF) I don't see why it would have trouble tolerating a 2.2:1 gear.
Old 05-16-2012, 12:58 AM   #23
daniel_f.
My Ride: 330iC
well, i donŽt think its about handling torque. i just donŽt like the fact that the second to third change is at ~86km/h
Old 05-16-2012, 02:42 AM   #24
TerraPhantm
My Ride: M3 & ZHP
Oh never mind, I thought you were saying the one transmission would need the 188 diff more than the other.
Almost every (US) E46 has a GM transmission anyway. I don't think I'd really care what the redline speeds are if I'm not doing the shifting myself anyway.
Old 05-18-2012, 03:08 AM   #25
SUHLeen
My Ride: 2005 Saleen Mustang
I have an auto 01 330ci with the ZF tyranny. I want shorter gearing also. Would the 3.64 or 3.91 swap be a direct swap?
Sent from my Galaxy Nexus using Bimmer
- Phil
11 335is - TT 7 spd DCT daily :)
05 Saleen Mustang - forged, stroked, blown,... and on some juice
01 BMW 330ci - Totaled by some bish!
Financial Help
SUHLeen is offline   Reply With Quote
Old 05-19-2012, 07:47 AM   #26
daniel_f.
My Ride: 330iC
You need a 188k with big (6 screws) pinion input flange. can be found at the 2.5L E83 M54B25 with MANUAL transmission.
you could also use a 3.91 diff from a M54B20 E46 with "Antriebsauslegung Export", but this one is only 168k (designed for less torque) and all 3 flanges must be changed. the problem in changing the input flange is, there is no statement how much torque the pinion nut must have. So you have to count the revolutions the nut is torqued down and use the same revolutions with the new input flange from your old diff.
and at the end of the day, youŽll have something like this
Old 05-19-2012, 11:42 AM   #27
SUHLeen
Is this a 3.64 or a 3.91? I would prefer the 3.91 if I'm going to do it but if the 3.64 is stronger and an easier of a swap, that is what I want. I want to be able to just unbolt my differential and bolt the new one on and start driving.
- Phil
Financial Help
Old 05-21-2012, 08:23 AM   #28
daniel_f.
My Ride: 330iC
So, you want a 3,64 from a ZHP.
Old 05-21-2012, 11:24 AM   #29
SUHLeen
Thanks Daniel! :thumbs: that is going to be my next project as soon as I can source a diff from a ZHP. Are both manual and auto ZHP diff's the same? I'm assuming I will need/want a diff from an auto
- Phil
Financial Help
Old 05-21-2012, 11:33 AM   #30
Steven747
My Ride: 05 330ci
hit up a euro junk yard
Old 05-21-2012, 12:03 PM   #31
TxZHP04
My Ride: ESS TS2+ ZHP
You'll definitely want to source from an auto. Manual transmission cars came with a 3.07 diff ratio.
Old 05-23-2012, 11:37 AM   #32
Karabogazgol
My Ride: 330i ZHP
I just destroyed my 3.64 ZHP diff 3 days after tranny swap
Went from Auto to Manual 6 speed with UUC lwf & clutch ... Diff was 93k miles only and it failed, one tooth broke
So I installed 3.07 from other ZHP (which is haaaard to find in Russia). Acceleration feels slower, but 0-100 km/h (0-62 mph) time is better as there's no extrashift onto 3rd gear at 80 km/h
We got lots of 3.38 diffs in Russia, will this be a better option for a Manual rather than 3.07?
Karabogazgol is offline   Reply With Quote
Old 05-23-2012, 11:56 AM   #33
TxZHP04
How'd you manage to destroy your 3.64?
Old 05-23-2012, 11:49 PM   #34
SUHLeen
Depends on what you want... 3.38 will get you better acceleration but it will lower your top speed. You will also get a little better gas mileage in the city. The 3.07 will give you a higher top speed, but lower acceleration, and a little better highway mileage.
- Phil
Financial Help
Old 05-24-2012, 05:25 AM   #35
Karabogazgol
My Ride: 330i ZHP
Suspect that bad diff oil caused it.
Never been changed and when we opened the diff the oil was totally black with ant smell in it
Shoot on the Moscow ring highway about 50 km run on high RPMs and after that heard the clinking sound somewhere in the rear.
Went straight to my mechanic who said that apparently one or two teeth are broken in the diff...
The guess was that old oil overheated causing parts to brake Even though I have Performance diff cover (33117512980) installed.
Old 05-24-2012, 08:34 AM   #36
TxZHP04
Never been changed and when we opened the diff the oil was totally black with ant smell in it .
That is a bummer. Sorry to hear.
Old 05-24-2012, 10:17 AM   #37
Karabogazgol
My Ride: 330i ZHP
TxZHP04
BTW how 3.64 feels with ESS TS2+? 1 & 2 gears must be really short with 350+ hp
330i ZHP '04 matte silver grey / Auto -> Manual 6 speed / Ebay headers no cat / UUC TSE 3 / SprintBooster / Proma BBK 17" / PSS10 / UUC strut & sway / UUC poly FCABs / UUC lwf + clutch / UUC SSK + DSRR / Forged 18" spokes wheels
Old 05-24-2012, 05:09 PM   #38
TxZHP04
TxZHP04
First is a little short but it's still manageable. Took a day or 2 for me to quit bouncing off the limiter after upgrading from the 3.23. I thought it might have been too short for me but I actually love it, turned out to be the perfect finishing touch to my car.
Old 06-19-2012, 06:32 AM   #39
daniel_f.
My Ride: 330iC
got it fitted last weekend and it makes a huge differnce compared to stock 3.38:1
iŽm using it with z4 tranny software and the modification to lock converter at 60km/h. it shifts stiffer, much faster and the engine sounds much more like a SMG then auto transmission.
definately worth to swap one of the best things one can do to his ZF tranny
Old 07-09-2012, 09:18 PM   #40
NaZty NaZe One!
My Ride: 02' 330ci "Ebony"
Send a message via AIM to NaZty NaZe One!
hahah finally! picked up a 3.64 with a finned cover. will be doing the swap soon. does it make a difference if it came from a z4 or a zhp?
Photobucket
NaZty NaZe One! is offline   Reply With Quote
