Old 07-09-2012, 10:28 PM   #41
Qik-BMW
My Ride: 04 3.0 Transplant
Originally Posted by NaZty NaZe One! View Post
hey everyone. im looking to change out my stock diff from my 02 33oci for a quicker more responsive differential. i read up on kpengs diff swap and like the improvements, however im still a little hesitant.
can i have some opinions on which to get the 3.64 or the 3.91. is the labor needed to install them the same (e.g., the 3.91 needing the longer drive shaft, etc)?
thanks in advance!
I have done both In my 325 auto. I first went with a 3.64 diff and I was not impressed with the difference. A month later I found a 3.91 diff and that is the way to go, nice difference with the 3.91. Now that I have done the manual swap I need a 3.46 diff back in her.
Qik-BMW is offline   Reply With Quote
Old 07-12-2012, 11:34 PM   #42
NaZty NaZe One!
My Ride: 02' 330ci "Ebony"
Send a message via AIM to NaZty NaZe One!
So I got her installed but haven't been able to really test her out. It's Definetly an improvement but not substantial. I definitely feel stronger off the line. I usually cruise around 80 but now because of the higher rpm's, I'll probably coast at 70-75 @ around 3k rpm. If I go higher it will be too much gas (80@ 3600rpm). I'll update it once I get a little used to it.
Photobucket
NaZty NaZe One! is offline   Reply With Quote
Old 07-12-2012, 11:57 PM   #43
Steven747
My Ride: 05 330ci
step on it from 1st gear through 2nd and into 3rd and you should feel a nice difference .. now is when you want to raise your rev limiter to take advantage of the shorter gears and stay in 1st and second longer
Old 07-13-2012, 12:13 AM   #44
daniel_f.
My Ride: 330iC
its definately more powerfull then with stock diff. once you drive it, you can feel it.
fuel consumption decreased around 1 liter
Old 07-15-2012, 02:03 PM   #45
NaZty NaZe One!
The power is there. Even when on the highway, you can press down and the car responds with more umf. You can really feel the power when trying to switch lanes too, you can punch it and it'll go.
Photobucket
Old 07-20-2012, 01:49 PM   #46
cinimod
My Ride: e46 5spd sedan
I'm getting in this too. I have a '99 5spd 323i.
What car comes with the 3.64 final drive factory? Or where can I buy just the gear?
I don't want to buy a whole diff. I'd much rather buy JUST the final drive gear then weld the diff.
cinimod is offline   Reply With Quote
Old 07-21-2012, 06:18 AM   #47
daniel_f.
My Ride: 330iC
Are you able to measure backlash and adjust it?
Old 07-21-2012, 07:35 AM   #48
cinimod
Don't know how too but nothing research can fix
Old 07-21-2012, 09:06 AM   #49
daniel_f.
My Ride: 330iC
sooo, according to bmwfans.info you have a 188k diff with 3.07 ratio. the automatic cars use a 3.46 ratio which should be more common then the 3.64 from a zhp. otherwise, you live overseas where zhps can be found, unlike here in germany.
so buying a zhp diff should be far easier then dealing around with adjustment shims and backlash measuring.
if you definately just want the gears, try to find them from a zhp diff.
Old 07-22-2012, 05:27 PM   #50
Bmw328monster
My Ride: 2000 328i
Originally Posted by NaZty NaZe One!<br />
hey everyone. im looking to change out my stock diff from my 02 33oci for a quicker more responsive differential. i read up on kpengs diff swap and like the improvements, however im still a little hesitant. <br />
<br />
can i have some opinions on which to get the 3.64 or the 3.91. is the labor needed to install them the same (e.g., the 3.91 needing the longer drive shaft, etc)?<br />
<br />
thanks in advance!
<br />
<br />
How much did the 3.92 diff cost you. I have an auto 2000 328i and would like more power
Bmw328monster is offline   Reply With Quote
Old 07-22-2012, 08:20 PM   #51
Qik-BMW
Originally Posted by SUHLeen View Post
Is this a 3.64 or a 3.91? I would prefer the 3.91 if I'm going to do it but if the 3.64 is stronger and an easier of a swap, that is what I want. I want to be able to just unbolt my differential and bolt the new one on and start driving.
The 3.91 is just as easy to swap and I am running a list of mods with a 75 shot of nitrous on my 3.91 diff with no problems!
Old 07-22-2012, 08:22 PM   #52
Qik-BMW
Originally Posted by Bmw328monster View Post
<br />
<br />
I think I paid $350. I am going to sell it in few weeks cause I need a 3.46 diff since I have done the manual swap.
Old 07-22-2012, 11:38 PM   #53
TrippinBimmer
My Ride: Just Fast!
Can buy my diff...of a ZHP...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 07-25-2012, 02:40 PM   #54
TiAg2247
My Ride: E39 M5 | E55 AMG
The M3 3.62 LSD is one of the greatest mods I've ever done. Short gears FTW!
Imola Red M5 | Imola Red Interior
GT Exhaust, Custom BC Coilovers, 19x10 + 19x11 Rial Dayonta Race, Michelin PSS
Daily: 335i M-Sport Alpine White / Coral Red
Too many mods
Past:
'04 E55 AMG
'01 330Ci Titanium Silver / Coral Red
'96 328i Jet Black / Black
TiAg2247 is offline   Reply With Quote
Old 07-25-2012, 02:54 PM   #55
Steven747
My Ride: 05 330ci
i would love to but freeway driving kills. i really want a lsd i might be looking into wavetrac before the summer is over
Old 11-23-2012, 04:03 AM   #56
Bmw328monster
My Ride: 2000 328i
Do you still need 3.46 diff?
Old 11-24-2012, 04:16 AM   #57
daniel_f.
My Ride: 330iC
Well, instead of my ealier postings i would NOT use a 3.91 diff anymore WHEN im allowed to drive topspeed. luckily our german autobahnen are sometimes unrestricted and now comes the tricky part:
the egs measures the turbine rpm in each gear and if in fifth gear ~5500rpm is reached, the dme is told to lower hp/torque. if the car still accelerates (driving down a hill) the transmission goes into limp mode and opens all clutches
thats what i found out yesterday on a dyno and i got somewhat upset when the car made a huge shake at ~ 240km/h and the malfunction lamp appeared.
if you arent allowed to cruise at really high speeds, 3.91 is ok. otherwise id go with the 3.73 or 3.64 unless the egs software can be changed to accept higher rpms in fifth gear.
