Old 05-12-2012, 04:03 PM   #1
RXPJCS3
My Ride: 330ci
Error codes taking turns.
My daughter has a 2003 330ci. Engine idle is rough and power is lacking.
I keep getting different error codes from one time to the next.
Got egr malfuntion code. I took the valve off and cleaned it. That code has not shown up in a few days.
She took it to parts store. They used their reader and sold her intake side camshaft positioning sensor. I replaced it. Problem not fixed. While replacing this found huge hole in vent hose that came off oil separator. When I plugged hole with my finger RPM's changed and it smoothed out a bit. I rigged up a piece of hose to replace it until parts can arrive.
Now code showing up most frequently is P0187 fuel temp sensor error.
Does this mean I need to replace the sending unit at the tank? Are there other issues that will cause this code?
Any body have any suggestions?
RXPJCS3 is offline   Reply With Quote
error codes, fuel, p0187, rough idle
