Old 05-12-2012, 04:30 PM   #1
NicB.
My Ride: 2000 BMW 328i
Cracking Sound When Braking
Hi Guys,
Have an unusual noise developing in my car. So for the past couple years, I have had this cracking noise from the front that evidences at random points in time, usually when pulling into a parking space (braking and turning the wheel). Over the past few years, most of my front suspension/steering components have been replaced (sway bar end links, FCB's, springs/shocks, tires, brakes, control arms).
Last night I backed straight into a parking space and when I applied the brakes I heard a sharp and noticeable CRACK. I pulled forward, stopped, CRACK. Weird. I pulled forward a little more, nothing. Went in reverse again, crack. Backed up a little more, nothing. Pulled forward, crack. The cycle continued.
Obviously, something is loading/unloading and causing the noise, I'm just not sure what it could be. This has stumped me for a long time and really irritates me.
Thoughts?
Thanks!
NicB.
NicB. is offline   Reply With Quote
Old 05-12-2012, 04:56 PM   #2
Ronnied18
My Ride: 2002 BMW 330ci
Originally Posted by NicB. View Post
Hi Guys,
Thoughts?
Thanks!
NicB.
The easiest thing I think is to post a video of the sound. The word "crack" to someone could sound different to somebody else. But I would recommend to check the clips thats secure the pads, control arm bushings or sway bar endlinks...Those are the only things that pop in my head that could make a "cracking" noise..
Super Deluxe Special Edition 330ci / Quad Turbocharged /
Autozone Shift Knob / Stickers for extra Aerodynamics
Ronnied18 is offline   Reply With Quote
Old 05-12-2012, 05:03 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
you did fcabs...make sure they're still okay...but I first thought of balljoint myself...check CAs. You can squeeze each ball joint with monster channel locks and try to get play there...off the ground, of course.
End links also have ball joint...and checking the brakes is a great idea too...check wheel lugs, and make sure you have both caliper carrier bolts in too.
Cracking is usually not a good kind of sound! But, the good news is that I bet it's visible!
Good luck...hth.
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
Old 08-29-2012, 10:39 AM   #4
Custom3
My Ride: HellRot 330CI
I have the same exact problem.... haven't had time to really look into it. Yesterday I looked real quick and noticed the sway bar end links rubber boot on the bottom of both end links were ripped. Im not sure if that would cause the cracking noise when braking. If all the grease came out of the end link then probably that would cause the noise? Ill have to look more into this when I have time.
Old 08-29-2012, 11:21 AM   #5
2003silver330i
My Ride: 03 BMW 330i
I guess I was thinking of something else like a loose brake pad shifting from momentum.
2003silver330i is offline   Reply With Quote
Old 04-13-2013, 06:14 PM   #6
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
bump...I think I'm facing something similar. No sound before my brake job, but I replaced rotors and pads and suddenly I get a weird "pop" sound when I shift momentum. Pulled wheels off quickly today and everything checked out visually, all the nuts and bolts were properly torqued still, pads sitting right up against rotor, and I couldn't see any space between the carrier and pad, but it wouldn't take much to make a pop like that I'd imagine.
-Chris
chris98891 is offline   Reply With Quote
Old 04-13-2013, 07:35 PM   #7
rdogthenut
My Ride: 2003 330i ZHP
I had similar symptoms and it was a shifting brake pad.
rdogthenut is offline   Reply With Quote
Old 04-13-2013, 11:38 PM   #8
chris98891
My Ride: '16 X6 50i
how did you fix it?
-Chris
Old 04-15-2013, 08:18 AM   #9
rdogthenut
I just disassembled, cleaned, and reinstalled with a healthy application of anti-squeal compound. Problem solved for me.
Old 04-15-2013, 07:31 PM   #10
chris98891
My Ride: '16 X6 50i
Awesome, thanks for the reply. I'll do that!
-Chris
