Old 05-12-2012, 06:05 PM   #1
tweeeker
My Ride: is getting modded
Engine swap vs DME
I want to swap my 325i with a 330i engine. Problem is, that the 330i is automatic. Does anyone know where i can get my DME re-programed? I really dont want to change my ignition n locks n keys etc...
miss u
tweeeker is offline   Reply With Quote
Old 05-16-2012, 01:50 AM   #2
TerraPhantm
My Ride: M3 & ZHP
Depending on what the timeframe is and where in Jersey you are, I could do it for you.
And why not just keep the transmission from your 325 with the 330 engine?
Old 05-16-2012, 07:02 AM   #3
j_block
My Ride: 2003 325i
I think he is saying he has a 5 speed and the 330 has an auto. Which means the dme is for an auto and not a manual? Maybe?
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 05-16-2012, 08:55 PM   #4
TerraPhantm
My Ride: M3 & ZHP
Maybe, but then he'd have to grab the ews and keys from the donor car. It'd be better to keep the 325 DME and flash the 330 tune onto it.
Old 05-17-2012, 12:30 AM   #5
tweeeker
actually, you guys are all kinda correct. I have a 325i. Have a 330i engine for an automatic. would like to prog my dme to the 330 engine....if possible.
miss u
Old 05-17-2012, 12:45 PM   #6
TerraPhantm
My Ride: M3 & ZHP
It's trivial to reprogram the DME. Auto vs manual doesn't matter. Just grab the flywheel and pilot bearing from your 325 engine, stick them on the 330 engine, and put the 330 engine in your car
Old 05-17-2012, 07:16 PM   #7
tweeeker
I get the mechanical part of it...but I would think that with the 325 DME and a 330 engine....1) won't the car look for the auto trans? 2) The values will be off? The reason i say this is because next summer i would like to super charge it....now with that it will come with software for the 330. Then what?..if I'm running the 325 DME.
miss u
Old 05-18-2012, 12:05 AM   #8
Hornung418
My Ride: '04 MB ZHP
You're not running a 325 DME. It's an MS43 DME. There is a part number that you select when programming it. You can use any MS43 DME to run a 325 or 330, as long as it has been coded to the engine in question. Tuning companies do the same thing when they are reprogramming it to fit your mods. You have nothing to worry about.
Hornung418 is offline   Reply With Quote
Old 05-21-2012, 07:51 AM   #9
tweeeker
Will i be able to run the 330 engine, from an automatic, with my MS43 DME with no issues? running rich? chk engine?, running rough, etc.....
miss u
Old 05-21-2012, 01:09 PM   #10
Hornung418
My Ride: '04 MB ZHP
Is it really that hard to comprehend? What else do you want us to tell you for you to understand??
Old 05-21-2012, 02:31 PM   #11
TerraPhantm
My Ride: M3 & ZHP
You have to reprogram the DME to the 330 software - both the 325 and 330 use the MS43, so reprogramming is trivial.
And I don't know why you keep mentioning that it's from an automatic. It has no relevance since you'd swap the flywheel and pilot bearing anyway. The engine itself has no software on it. As long as there's no automatic transmission plugged in at the time of programming, it won't look for a transmission controller
Old 05-24-2012, 12:00 AM   #12
tweeeker
.....thank you for your 411
ok GOTCHA! thank you.
miss u
