Sponsored by The Tire Rack
Old 05-12-2012, 07:22 PM   #1
SMGE46
My Ride: 330i ZHP
Fitting 19s on 330i
I am trying to know if this set of rims and tires would fit on a 330i 2004 ZHP. The fronts are 19x8.5 ET35, 235/35/19. The rears are 19x9.5 ET38, 265/30/19. Michelin Pilot Super Sport Tires. Any help would be much appreciated and all opinions valued.
Thank you.
SMGE46 is offline   Reply With Quote
Old 05-12-2012, 07:27 PM   #2
E46mike-izzle
My Ride: 330ci
Should be fine
-Mike-
E46mike-izzle is offline   Reply With Quote
Old 05-12-2012, 07:27 PM   #3
HyeWarrior
My Ride: '03 325i --> '13 GTI
The rear tires seem a little beefy. I don't think you'll have a problem if you're not lowered
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 05-12-2012, 07:29 PM   #4
Au2bahn
My Ride: 05 330i ZHP,09 HCHII
You will rub if you lower
Sent from my DROID RAZR
Jon Estrella
ESS TS2 - VMR V710 19" wheels - KW Coilovers - 3.46 Diff - Macht Schnell 5mm Rear Spacers - BMW Performance BBK w/ floating rotors -
BMW Performance Strut Brace - BMW Performance Air Intake - BMW Performance SSK/DSSR - Hawk HPS Brake Pads - SS Brake Lines -
OEM M3 RTAB w/ Vorshlag Limiters - Meyle HD FCAB - TMS Sway Bars w/ adjustable links - AEM Digital Boost Gauge -
Stewart w/p - 6K HID Fogs - Swain Coated Magnaflow headers
Au2bahn is offline   Reply With Quote
Old 05-12-2012, 07:34 PM   #5
AE46fanaticlol
My Ride: looking for an E46
Didn't you just post this earlier
Originally Posted by TurboMliner View Post
Yes, the engine runs perfectly with no problems. The motor is not damaged in any way. Just has a bit inside the head.
AE46fanaticlol is offline   Reply With Quote
Old 05-14-2012, 06:51 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
That rear sizing looks a bit aggressive. If you're not planning on rolling your fenders or anything like that I wouldn't recommend that setup.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
