Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 05-13-2012, 06:35 PM   #1
Marinerd
My Ride: 04 xiT, 09 328i
FINALLY fixed my vacuum leak problems
So pretty much ever since I got the car I've been battling the dreaded p0171/174 code problems. I'd replaced pretty much everything you can think of relating to vacuum:
CCV (Valve and Hoses)
Fuel Pump and Filter
Upper and Lower tubes to the MAF
All SAP hoses
VCG
DISA seal
ICV seal
You freaking name it....
Finally I read a thread about one specific very small and practically free potential fix.
Back behind the Manifold where the SAP hoses goes next to the firewall there's an opening tubed up with a rubber cap. Pic below where the white cap is (not my picture)......
So that white thing on there is not what is stock. Its a black rubber cap that's apparently prone to get brittle and cracked thus allowing un-metered air into the system causing the lean codes. The cap is below (again not my picture).....
Well my cap looked almost identical to that with another small crack on the other side. Since I couldn't find anything around the house to replace it and didn't really feel like going out to a parts store to find something I decided to MacGuyver it.
I grabbed some Gorilla glue and generously applied it. Let it get tacky then held it till it dried. I then grabbed some electric tape and wrapped it up real good. Gave it a couple more hours to really cure and reinstalled it.
After putting everything back together, clearing my codes, and eventually driving over 1000 miles I'm glad to say this very simple fix solved my very annoying lean code problems. What a relief. Hopefully this will help some of you guys with the same symptoms.
Just thought I'd also include some of the symptoms I got because of the lean codes.....none. I literally wasn't getting any noticeable symptoms. No rough idles, hesitant or weak starts from stop, nothing. That's what made it even more frustrating. Everything was running just fine with the codes. The only thing I would probably say is my gas mileage was definitely taking a hit, and now I've noticed it getting generously better.
Later all.
Marinerd is offline   Reply With Quote
Old 05-13-2012, 07:21 PM   #2
SHK&BAK3
My Ride: rustles jimmies
I have the same problem but it only happens in the winter. here in nc when it gets cold i will get these two codes clear them and every winter it comes back has been happening for three years now. if i do this to my car and it fixes it, i will forever owe you a thank you!
SHK&BAK3 is offline   Reply With Quote
Old 05-19-2012, 11:05 AM   #3
Marinerd
Yeah my codes were definitely more prominent in the winter. They'd simply stay on. Once the warm weather rolled around it would be a lot more intermittent. Usually on for couple hundred miles, off for a couple hundred miles. Now its gone for good.
Old 05-19-2012, 11:19 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Haven't seen that part here described before. Nice work man
Old 05-19-2012, 12:18 PM   #5
jdstrickland
My Ride: '94 325iC & '00 323i
While the rubber cap you found will certainly cause the problem you describe when the cap is in the condition you show, I'm not sure fixing it with Gorilla glue is the right thing to do. You can buy those rubber caps at the auto parts store.
Old 05-19-2012, 06:31 PM   #6
Marinerd
Yeah it was more of a temporary thing to see if it would solve the issue. I'm still procrastinating the search for a suitable replacement. Just been busy.
Old 06-02-2012, 03:01 PM   #7
Scubajet
My Ride: 2000 323I
I'm having some vacuum probs as well, but I'm not sure where to find that plug/cap. Do you have to take off MAF and boot to ICV to see it under there? I cant find it otherwise. Thanks for your help!
Scubajet is offline   Reply With Quote
Old 06-02-2012, 03:22 PM   #8
Marinerd
Yes, you need to remove the cabin filter holder, airbox, maf, and boots at the very minimum. It would also help and give you more room to work to take out to separator between the brake components/ECU and the engine pictured below.
Old 06-02-2012, 04:16 PM   #9
46driver
My Ride: 330i
I hope it works for me
I just bought my e46 and it has the same lean code with no symptoms. tomorrow was my tear apart the intake day but now hopefully I can focus my search. great pics.U
46driver is offline   Reply With Quote
Old 06-02-2012, 06:06 PM   #10
jfoj
My Ride: 330CiC, M5, X5
46driver,
Suggest you read the first link below in my signature. I think you might find it helpful?
Good luck resolving your issue.
Old 06-05-2012, 11:55 PM   #11
46driver
My Ride: 330i
My Cap was barely cracked, replaced it and still got the codes. On to the links for further trouble shooting.
Old 06-06-2012, 09:11 AM   #12
ccagle
My Ride: 02' 325i
46driver,
If you follow his "process" in his link and you don't fix your problem, you either didn't read enough or shouldn't be working on the car period... His link is a gold mine of info and, if followed properly, will resolve any vacuum leak issue..... Just say'n.....
ccagle is offline   Reply With Quote
Old 06-06-2012, 10:51 AM   #13
Quenotte
My Ride: E46
Is it part #11 61 1 437 560 ??
Quenotte is offline   Reply With Quote
Old 06-06-2012, 11:52 AM   #14
tcek
My Ride: BWM 325Xi - 2004
i guess we can assume that's not your crotch in the picture. lol
tcek is offline   Reply With Quote
Old 06-06-2012, 05:34 PM   #15
Marinerd
Ha. Definitely not my crotch.
Probably. Not exactly sure from pics of the part. If you go to any major parts store you can find vacuum caps pretty easily.
Old 11-14-2012, 03:18 PM   #16
eph6jonprice
My Ride: 2001 330Ci
46driver,
I am working through your extremely helpful link, but I am getting code P1192, and am having very "jerky" driving when the engine is cold that seems to mostly subside when it is hot... any advice on this code? Replaced all four O2 sensors and found that my fuel filter didn't even have a line attached to the f-connector! But honestly, after removing the DISA and inspecting, and fixing the line to the fuel filter regulator, the car has driven even rougher than before, but could be a coincidence since the cold weather really just hit. Thanks for any suggestions!
eph6jonprice is offline   Reply With Quote
Old 01-07-2013, 10:09 PM   #17
Landlorder
My Ride: 330CI Sport
Me too, when reconnecting the f connector hose to fuel filter, my car initially ran worse ! Has cleared up over time but still not perfect...
Landlorder is offline   Reply With Quote
Old 01-07-2013, 10:15 PM   #18
eph6jonprice
My Ride: 2001 330Ci
Turns out I was 3 quarts low on transmission fluid, which no one mentioned was not the "ATF" cap on the top of the engine... I'm sure this was a rookie mistake, but where was the logic in putting the initials for Auto Tran Fluid on the Power Steering reservoir? Anyway, off the rant, definitely check your transmission fluid, could have really ruined it if I had driven it that low much longer!
Old 01-14-2013, 10:56 AM   #19
TArse
My Ride: 03 330xi, 87 325is
in for my search later today.
TArse is offline   Reply With Quote
Old 01-14-2013, 11:08 AM   #20
WDE46
My Ride: 2004 330Ci OBM
It is confusing for people coming from other cars. The cap says "Use ATF only" and "ZF" if it's OEM. That's confusing since a lot of people know the cars have ZF transmissions. It should say something like "Power Steering reservoir USE ATF ONLY".
