Old 01-16-2013, 09:36 PM   #41
spdracr137
My Ride: 323i
Originally Posted by SeanC View Post
Interestingly enough, I had a single misfire code on that same cylinder. Had to replace the fuel pump, and no more misfires.
This happened to me too. I replaced, ccv, disa, plugs, tried swaping coils/injectors, checked for vacuum leaks and it ended up being my fuel pump. Doesn't make any sense to me but my pump died one day and after replacing it, the missfire never came back. Still have no idea how that caused only a single cylinder missfire but it did.
spdracr137 is offline   Reply With Quote
Old 04-24-2015, 12:49 AM   #42
kezzzer
My Ride: E46
same issue
i have the exact same issue and i put a new pack and plug in there, yet once it warms up a bit it does start to misfire. i have the C110 diagnostic tool for bmw and i can tell you he was correct as in once you reset/ erase the code the car does run better for a few mins before it does it again. i was going to replace the wiring loom thinking it maybe has a bad wire inside but if any of your was fixed by a new fuel pump then i will be chacking the pressure for sure as well as the piston pressure. will let you all know but it is a wierd fault, how did you put it?? the computer does not reset and it runs fine after..but it does
kezzzer is offline   Reply With Quote
Old 04-24-2015, 12:52 AM   #43
kezzzer
My Ride: E46
as i noticed on mine at this point you are wrong !!! the car DOES seem to say its reset now run ok coz thats exactly what happens. i believe it may be a fuel pump issue but will test pressure
Old 04-27-2015, 10:07 PM   #44
kezzzer
My Ride: E46
same issue
same cylinder also. tried trading packs plugs and injectors but no good as same fault next step compression test. interesting side note for you though as i read a few of these posts i tried new things as they were posted and found a video on youtube that shows if the rings look bad they may not be as its a thing with these cars so ordered the X66p upper engine cleaner just in case.
As i said.... a side note last time i started it 2 days ago after moving injectors i noticed i could not hear the pump under the seat but the cover was on. can't you normally hear it anyhow??
Stumped
Old 06-22-2016, 07:32 PM   #45
412ZHP
My Ride: 2003 330i ZHP
Same cylinder 5 misfire problem. If I clear it will come back, sometimes along with misfires 4 or 6, but I had Carsoft 6.5 connected and it indicated a cylinder 5 misfire first. First replaced 5 and 6 cylinder coils and plugs, as these were throwing codes first, didn't help. When I rev past 3500-4000 at a standstill, on the way back down to idle I hear a strange tapping sound with rpm dips, evens out after 10 seconds or so. When driving up a hill, the vehicle will not exceed 4000 rpm even when floored, then it enters a limp mode nearly stalling while returning to idle. I hear a sort of whirling around my air distribution equalizer, just changed out the 6 o rings on that. Inspected all intake boots, replaced throttle body gasket, cleaned throttle body and ICV, cleaned MAF, replaced DISA o ring and inspected it by holding my thumb over the hole, the DISA flap held in place and seemed to function properly. Replaced CCV.
Next on my list would be fuel pump, any other suggestions?
Thanks for your help in advance!
Tony
412ZHP is offline   Reply With Quote
Old 06-22-2016, 08:10 PM   #46
jfoj
My Ride: 330CiC, M5, X5, E93
http://forum.e46fanatics.com/showthread.php?t=1052977
http://forum.e46fanatics.com/showthr...1#post16833498
http://forum.e46fanatics.com/showthread.php?t=870338
Old 06-22-2016, 08:43 PM   #47
412ZHP
The DME is one area I didn't check, I'll do some diagnosing when I get off work. Looks like a blast!
Thanks for the suggestions
Tony
Old 12-29-2016, 02:46 PM   #48
DLUXQ
My Ride: 2000 323I
Issue resolved?
Did this turn out to be your issue, I'm having the same problem with mine! And so far I've done what you have to correct it, plugs, switching coils, etc..
Thanks, Dave
Originally Posted by rfbmwfan View Post
Ok, so.. last night I left the battery charger on by accident. However, this morning on the drive to work, I kept waiting for the car to start missing, and nothing.
So then today I drove it around some more.. battery is staying around 12.5V. Alternator output is 14v without load, 13.8 with load. I don't recall.. isn't charge supposed to stay around 14.5v?
I think this is a voltage issue. The problem kept coming and going. If I was in stop and go traffic, the car would slowly start missing. If I was getting all the green lights and in the higher revs, the car would return to normal.
Seems kind of strange though..
DLUXQ is offline   Reply With Quote
Old 12-29-2016, 03:19 PM   #49
bach6177
My Ride: 2010 n63 X6
Did you swap at the plugs or did you just look at them? I would highly recommend swapping plugs
bach6177 is offline   Reply With Quote
Old 12-29-2016, 04:37 PM   #50
DLUXQ
My Ride: 2000 323I
I replaced the plugs/boots/moved the coils around/replaced idle control valve, I believe I have narrowed it down to the DISA, I cleaned it and that seems to have temporarily solved the issue. I know this thread is a few years old, I didn't see a definitive issue resolve post and I was hoping the original poster would respond. Thank you.
Old 02-23-2017, 06:37 PM   #51
Mainebmw
My Ride: 330XI
Misfire on #5
Hello,
I wanted to see if anyone could help me with the following issue.
Out of the blue, I started to feel a vibration in the engine. The engine had been running and was up to operating temp. The service engine soon light came on. I read the code and it was PO305 - misfire #5. Since then, I have swapped parts from companion cylinders. One part at a time. I clear the code each time and run the engine to see the result. I have swapped - fuel injectors, coil pack, spark plugs. The issue always stays with #5. I have pinned out the power and signal for in the injectors. I have 12volts at the coil connector and I have pinned out the signal wire on the coil. I have done a leak down test on the cylinder.
To the best of my knowledge, I have checked all single cylinder related issues. Any other ideas as to where to go next? I'm really hoping this isn't an ECM problem.
Any ideas would be greatly appreciated.
Mainebmw is offline   Reply With Quote
Old 02-25-2017, 01:24 PM   #52
DLUXQ
My Ride: 2000 323I
Wish I could help, I'm still trying to find my rough idle issue! #5 as well
Old 03-12-2017, 06:10 PM   #53
Mainebmw
My Ride: 330XI
So I found my issue. It turned out to be a coil pack, but much to my surprise it was the #6 coil pack that was causing the misfire and yet the computer was throwing a code for #5. Don't fully understand how that can happen, but a new coil pack in #6 and I'm good to go again.
Old 03-12-2017, 06:19 PM   #54
tritron
My Ride: 325i
Read the post. Already done all that. Compression is 120 in all cylinders.
Sent from my SAMSUNG-SGH-I727 using Bimmer App
Did you use harbort freight compressor tester. You need compressor tester that has valve in hose for accurate reading.
tritron is offline   Reply With Quote
Old 03-12-2017, 06:59 PM   #55
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
It could have been something on #5 such as the boot, connector, wiring, etc., and installing the #6 coil moved it enough to "fix" the glitch. Why did you install a new coil on #6?
///Mmmmmm...
