Engine & Performance
Everything to make your car faster! Air intakes, superchargers, turbos, flywheel & clutch, differentials, chips, short shift kits, exhausts, etc..... |
#1 |
FS: New Z4 3.0 shifter
(1) New Z4 3.0 shifter.
SOLD!!!!! Mounted, but never used as I didn't like the way it sat. Will make an excellent ssk, doesn't hit driveshaft or guibo, but it does move neutral slightly up and to the right, not enough to interfere with shifting, but I just didn't like it. There are some tool marks on the shaft between the rubber bushing, and the pivot ball, the bottom part of the bushing casing is also slightly pinched. All of this was caused by me trying to put a slight bend in it ( it's a straight design) doesn't affect functionality of it, but I prefer full disclosure. Can be seen in the pictures with m holding it to show this slight crimping. ![]() ![]() ![]()
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF SplittersM3 - Not enough room to list Last edited by lejeunebimmer; 05-18-2012 at 12:13 PM. |
#2 |
Bump
Sent from my SPH-M900 using Bimmer App
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF SplittersM3 - Not enough room to list |
#3 |
will this be a good fitment for a 00 328i sport. I don't want to bench anything to make it fit.???
#4 |
All of the 5 speed manuals it will fit into, and clear the drive shaft no problem.
It'll give about a 30% reduction in shift effort, you can still get into all gears no problem. The only draw back is that neutral moves slightly up and to the right. Nothing major, but I'm really anal about it so that's why its up for sale. Sent from my SPH-M900 using Bimmer App
#5 |
I will do 35 shipped to 78240 will u do that. if so we got a deal.
#6 |
PM'd
#7 |
Sold!
