Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 05-16-2012, 12:43 AM   #1
02scm3
My Ride: 2002 m3 smg
2002 Supercharged M3 SMG. 66k miles
Hello Guys.
The time has come to sell my car and invest in a business opportunity.
Here is a list of specs and modifications on the vehicle.
I should also note I recently spent about 8k on parts/labor on the clutch, flywheel, new supercharger setup, and tires. Overall I think I have 25k into it or so, I have most of the receipts.
Engine:
-Active Autowerke stage 3 s/c/ setup (largest rotrex out, c38-91 trim, 75mm pulley, injectors, alpha-n, chip, pulleys... water/alcohol injection...) less than 500 miles on new s/c.
-larger cooler for supercharger than factory, 13row instead of 10 row
-larger air k/n filter than factory
-Rogue performance engine mounts
-Headers, mid section, remus muffler (nice flow not too loud)
Gearbox:
-Spec stage 2 carbon ceramic clutch (better than hpf feramic which I had before)(less than 1000 miles)
-New factory flywheel (less than 1000 miles)
-New driveshaft guibo
-Rogue performance transmission mounts
Suspension:
-T.C. Kline double adjustable track coilovers (550/650 rates I think, nice performance for the street)
-UUC rear trailing bushings
-rear spherical upper shock mounts
-rear adjustable lower control arms by Turner iirc
-Front camber plates with spherical bearing
Wheels/Tires:
-Iforged track edition TE-16 19" all around (perfect fitment for lowered stance)
-Bridgestone Potenza 245/275 19" (good tread life, about 60% left all around)
Brakes:
-UUC motorsport 4 wheel BBK, 355mm front, and 330mm rear, slotted rotors, great brake setup, excellent pad life
Interior:
-Innovative Motorsports digital boost/vacuum gauge concealed in center ashtray
-Innovative Motorsports digital Air/Fuel ratio meter in center ashtray (can connect to p.c. to log as well)
-Analog vacuum/boost gauge located on center steering column
-Carbon Fiber shift paddles, larger than stock
-Carbon Fiber steering wheel insert
Exterior:
-Rear bumper lower carbon fiber diffuser
-Front bumper lower carbon fiber splitters CSL style
-Tint on side and rear windows
-Professionally Tinted rear L.E.D. tail lights
Im pretty sure that is all of the modifications.
The car has been serviced above bmw spec, oil changes every 2500-3500 miles, less if I have time, and the higher end when I was busy. New filter and oil every time. It has also had its valves adjusted a couple thousand miles agom so you are good there for quite a long time as well.
Any questions please ask, and if your local and serious, perhaps youd like to arrange a viewing. Im in the Beverly Hills area.
$29,000
Thanks for looking.
ID:	451813   Click image for larger version
ID:	451814   Click image for larger version
ID:	451815   Click image for larger version
ID:	451817   Click image for larger version
02scm3 is offline   Reply With Quote
Old 05-17-2012, 11:18 PM   #2
Dan1983
My Ride: X3 35i, MaxPsi M3
great color, GLWS
Maximum Psi M3
http://img19.imageshack.us/img19/2906/newpicy.jpg
Dan1983 is offline   Reply With Quote
Old 05-18-2012, 11:01 AM   #3
02scm3
Hi Dan. Thanks, its my favorite color as well!, it goes so nicely with carbon fiber upgrades if one chooses to go in that direction with it...
A couple more pictures as requested.
Also to answer a couple questions:
1. Its maximum boost is around 8.5psi
2. It should make a little over the advertised hp of the kit, 520hp, so maybe 540hp, or about 490whp.
3. It can get up to about 520whp as noted by other cars with the same supercharger
If you would like to speak by phone, please PM me, or post here, and I will provide my cell.
Thanks!
ID:	452130   Click image for larger version
ID:	452131   Click image for larger version
ID:	452132   Click image for larger version
Old 05-22-2012, 10:35 PM   #4
02scm3
$28,000
Old 05-24-2012, 06:14 PM   #5
02scm3
bump
Old 05-27-2012, 01:22 AM   #6
02scm3
More pictures available upon request
Old 05-29-2012, 01:01 PM   #7
02scm3
$27,500 Firm.
Old 05-31-2012, 12:59 PM   #8
02scm3
Thanks for looking
Old 06-02-2012, 08:59 PM   #9
02scm3
Autotrader Ad:
http://www.autotrader.com/cars-for-s...ngId=323341392
Old 06-06-2012, 11:51 AM   #10
02scm3
I only have a few of the stock items left.
Headers, mid-section, stock tail lights, diffuser, and all the pulleys that were replaced during supercharger upgrade.
If I had the stock items, I would consider returning to stock and selling as the price difference is so small, im selling my 25k in upgrades for something like 7k.
Old 06-07-2012, 01:11 PM   #11
02scm3
Bump to the top please. ; )
Old 06-18-2012, 05:33 PM   #12
02scm3
$26,000 firm
Old 06-18-2012, 05:42 PM   #13
RedefinedM3
My Ride: '93 332i
Send a message via AIM to RedefinedM3 Send a message via MSN to RedefinedM3
A few grand more and I'd be all over this. Nice looking car!
**Some people are like slinkies, they are not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs**
RedefinedM3 is offline   Reply With Quote
Old 06-20-2012, 12:50 PM   #14
02scm3
Hey redefined.
A few grand less and Id be keeping this thing for a long time lol. Thanks for the bump.
Old 06-20-2012, 08:15 PM   #15
frankblank
My Ride: 01 M3
SES light or smog issues?
frankblank is offline   Reply With Quote
Old 06-20-2012, 08:31 PM   #16
02scm3
No lights on at all. The AA software I have is programmed to run with the setup...no maf, bigger injectors, headers, etc...
Old 06-26-2012, 01:54 AM   #17
02scm3
Bump for m3
Old 06-27-2012, 01:44 PM   #18
02scm3
What car should I get next? hmmmm
Old 06-28-2012, 12:55 PM   #19
02scm3
$25,000
Old 07-01-2012, 02:31 PM   #20
02scm3
Bumpity bump
