Old 05-16-2012, 03:08 PM   #1
trondk
My Ride: 330 XD
Vibration on low RPM, E46 330XD
Hi
I`m suffering from a very annoying problem.
On RPM`s 1500 to 2000 with just a little load on the engine I get a vibration / shudder through all gears.
If I open the throttle up and give the engine a good load everything seems fine.
I think I have concluded that gearbox / clutch is not the issue since it disappears with load and is present on all gears.
Any ideas?
trondk is offline   Reply With Quote
Old 05-17-2012, 08:24 AM   #2
eweis
My Ride: 1999 328i
Guibo, bent wheel, bad tire...?
Sent from my EVO
eweis is offline   Reply With Quote
Old 05-17-2012, 08:32 AM   #3
trondk
My Ride: 330 XD
Thanks for your reply! The vibration is not in the steering wheel but I had the tires check to be sure. No effect thou
The vibration seems to origin from the engine or drive train
