Old 05-16-2012, 06:51 PM   #1
Tex323GripIsKey
My Ride: 2000 323i Green
Are these correct OEM spark plugs?
http://www.autozone.com/autozone/par...9323_199221_0_
2000 323i
Originally Posted by Sweetness View Post
I used to drive fast and cowboy around, but then I realized that I can't even afford bumping into someone, so now it's slow and classy, with occasional spurts of speed. Fanatics might pick on each other from time to time, but we are all one great big family that looks out for each other in the end.
I pull up to meets, lean to one side, shakin my finger at all da playahaterz. Then I get back into my car and flash mah beamz.
323i brakes & rotors
Tex323GripIsKey is offline   Reply With Quote
Old 05-16-2012, 08:14 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
No, that's the 4418 (FGR8DQP) and is not the stock heat range. For Bosch, you would want the 4417 (FGR7DQP).
Personally, I would recommend going with the NGK BKR6EQUP over the Bosch plugs.
Old 05-16-2012, 08:20 PM   #3
Tex323GripIsKey
Link me bro! Reason for preference?
Old 05-16-2012, 09:10 PM   #4
TxZHP04
Just google "NGK BKR6EQUP", plenty of places to buy them. The Bosch have a reputation for being somewhat less reliable than the NGK.
