Old 05-17-2012, 10:03 PM   #21
Platinum Plus Quality
My Ride: M54B30
Originally Posted by LiNk504 View Post
yep wind comes out of the vents no matter what. I keep thinking that there is more air but i cant seem to get it out if there is. I think ill order a new tstat and a new fan and see if that fixes the overheating problem.
Just order a new t-stat and expansion tank cap. Hold off on the fan for now. How long did you bleed? (how long did you observe bubble-free water emerge from the bleed screw?)
(if the car cools as speed increase OR if the fan is not running while car is idling and hot, then its the fan)
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 05-17-2012, 10:10 PM   #22
BeMyWhip
My Ride: 01 BMW 330ci
may not even be the fan, it may be the fan switch in the lower radiator hose.
try that first. Good to have a new one anyway $26 from BMAutoparts.com for BMW brand
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 05-17-2012, 10:14 PM   #23
My325XI
My Ride: 03 325XI Sprt Prem
If your fan is working, sounds like a thermostat issue. Rebleed after that to see if the heat comes back. Check this DIY
http://www.bmw330ci.net/maintenance/completecoolant.php
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 05-17-2012, 10:47 PM   #24
LiNk504
My Ride: 2000 323i
I already got the new cap on there, and i saw bubble free water come out for about twenty minutes the last time i bled. Ill hold of on the fan and try the t-stat, its time for a new one anyways.
ill try that first, thanks!
thanks for that link, that should help too
Stupid f**king plastic parts!
LiNk504 is offline   Reply With Quote
Old 12-08-2012, 04:05 PM   #25
Garrow23
My Ride: 2000 323i
Same prob
Did the t-stat fix the problem? Did you have to replace the fan? I have an automatic and I can get the fan to come on for the AC, but not when the coolant gets over 115 degrees C.
Garrow23 is offline   Reply With Quote
coolant, head gasket, over heat, overheating
