Old 05-18-2012, 01:23 AM   #1
Alexandrle330ci
My Ride: e46 BMW 330ci Sport
Speed limiter removed? How to check!??!
Ok before you state the obvious(dyno test, or take it on a straight away) let me say, I have a 2001 330ci and I have read that these are limited to 128, correct? Well a few days ago I was on a clear straight of highway and got her up there, she sailed right past the 128 mark, and was still climbing strong, I have heard that your spedo will read around low end 130's because it's not accurate at those speeds? But, I reached about 143-145 on my spedo before slowing down due to coming up on traffic. So I'm thinking the limiter was removed. But I wanted to see if y'all knew a way to check manually? Just to fulfill my curiosity. Thanks!
Alexandrle330ci is offline   Reply With Quote
Old 05-18-2012, 01:28 AM   #2
fastjasonbmw
My Ride: 330Xi
BMW speedometers have a 10% error built in, so your 143mph is actually closer to 129mph.
You may be able to get a better speed reading from a very accurate GPS device.
fastjasonbmw is offline   Reply With Quote
Old 05-18-2012, 01:38 AM   #3
Alexandrle330ci
But either way that's still over 128 hahaha. No but seriously. Why do they have that built in? What's the purpose?
Old 05-18-2012, 01:47 AM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
I always thought the sports package cars had the limiter set at 150/155
Old 05-18-2012, 01:50 AM   #5
Alexandrle330ci
My friends e90 sport is limited to 155. I've heard all e46's excluding ///M's are at 128.
Old 05-18-2012, 02:01 AM   #6
B_Cyrus
Banned User
My Ride: Malfouf
This isn't extremely accurate. I took the MPH reading from GPS in my old e46 at 120mph on the speedo, and the GPS read 118mph. Not 10%, but not spot on either.
B_Cyrus is offline   Reply With Quote
Old 05-18-2012, 02:01 AM   #7
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
Mine was/is a sport package, and my limiter would kick in right around 140 indicated fr me. With the tune i did get it just north of 155 but that was obv. After I got the limiter removed,
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 05-18-2012, 02:04 AM   #8
fastjasonbmw
My Ride: 330Xi
lawyers, tire wear, tire size & less speeding tickets.
Old 05-18-2012, 02:11 AM   #9
fastjasonbmw
My Ride: 330Xi
Yeah but alot of gps' aren't super accurate either. You really need a military spec gps. Or have a laser clock your speed.
Either way who cares, unless its a racecar.
Old 05-18-2012, 02:15 AM   #10
B_Cyrus
Banned User
My Ride: Malfouf
Stock E46 = racecar, duh.
Old 05-18-2012, 02:24 AM   #11
Alexandrle330ci
I just kept going up and up and I was in shock because I thought it would have stopped at 128 or so. But no indicator light or anything came on? I don't even know what it does when it hits the limiter. Apparently I didn't reach it if I had one
Old 05-18-2012, 12:15 PM   #12
lejeunebimmer
It hits it at about 5.5k in 5th if I remember correctly.
No lights or anything common, it's just similar to hitting the rev limiter, it cuts fuel for about a sec, every few secs.
Old 05-19-2012, 03:32 AM   #13
Alexandrle330ci
Well hmm. Mine was still going strong. I guess I have to dyno it
Old 05-21-2012, 11:40 PM   #14
TerraPhantm
My Ride: M3 & ZHP
ZHPs and euro models are also limited to 155
Old 05-22-2012, 01:01 AM   #15
Steven747
My Ride: 05 330ci
mines at 128 can't wait for shark
Old 05-25-2012, 09:18 PM   #16
greenskycity
My Ride: 1999 328i
Its always been my assumption that speed limiters were set to the max speed of the OE tire. I'd say non sports came with H rated tires that are limited to 130ish and sports came with V rated tires that were good to 149. M cars came with Z tires so those cars were limited to 155 regardless because of the Germans self imposed 155MPH agreement. That's just my take on it though.
Green.
Sent from my Galaxy Nexus using Bimmer App
greenskycity is offline   Reply With Quote
