///M3 Forum
Old 09-29-2012, 04:27 PM   #1
cheerio89
My Ride: Blue E46 M3
Oil leak - E46 M3
I replaced my alternator 2 days ago. Today Im driving and the car starts smelling inside and a bunch of smoke behind me. I come to work and there is a puddle of oil that my car created! Im not sure exactly what is leaking yet. I'm pretty sure its not the valve cover gasket. Maybe anyone has had a problem like this and can tell me where its coming from before I take everything apart? Here is a video:
Thanks!
cheerio89 is offline   Reply With Quote
Old 09-29-2012, 04:52 PM   #2
jhaurimn
My Ride: 01' 330ci
Not really sure ... You are sure it's not the valve cover gasket? I think I've heard that the vanos solenoid can leak oil, perhaps that is what it is. Hard to tell what I'm looking at from your video
Edit : what did you take off when replacing your alternator ?
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 09-29-2012, 05:59 PM   #3
cheerio89
Air filter bucket, the plastic right next to the alternator, and the belt. Also took of the hose from the radiator it was in the way. Reference pic: http://imgc.classistatic.com/cps/bln...457db3_20.jpeg
Old 10-01-2012, 07:44 PM   #4
cheerio89
Here is a picture from underneath
Old 10-01-2012, 08:09 PM   #5
emax
My Ride: 06 M3
Clean the area and use UV dye to find the leak. Anything else is guessing.
'06 CB/IR w/SMG/NAV/HK/19" BBS RGR/Hankooks
emax is offline   Reply With Quote
Old 10-03-2012, 09:36 PM   #6
cheerio89
I didnt really have access to UV dye, but I did find the problem!!
This is the Vanos oil pressure accumulator. The line goes to the Vanos system showed the below picture. The line is under high pressure and was leaking oil on IDLE and spraying on high RPM (had someone rev it for me while I was under the car).
This is where the line goes.
Ordered new line: http://www.ecstuning.com/BMW-E46-M3-S54_3.2L/ES23258/
Old 10-04-2012, 12:42 AM   #7
jhaurimn
My Ride: 01' 330ci
Glad you found it ! Looks like it was leaking pretty good.
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 10-04-2012, 06:41 PM   #8
emax
My Ride: 06 M3
Good news. BTW you can get dye at your local auto parts store or online.
