Old 05-20-2012, 02:35 AM   #1
Ballistic325
My Ride: slow and steady
Exclamation Steptronic Sport to Auto mode issue
Hi guys
Need some help with my steptronic shifter.
The shifter will move to into Drive and into sport mode no problem. I can use it manual mode and again, no problem.
The problem occurs when moving the shifter back from sport to auto mode. The movement is not smooth and if feels as though the shifter is catching. In order to move back into auto mode, I need to jiggle the shifter back and forth a little for it to move across completely.
I removed some of the trim for a peek at the shifter mechanism and it looks like there is a broken grommet or bush - not sure what to call it.
This picture shows what it should look like (taken from the "DIY: Auto <---> 5 Speed Swap Lots of Pixs!!!" thread by Ivegotissuess666:
This picture shows what mine looks like:
In the red circle you can see where there is a broken piece.
Any ideas on fixing this will be very greatly appreciated.
Cheers
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 05-21-2012, 10:00 PM   #2
Ballistic325
Bump.... any thoughts guys?
I can help with
* RTABs
broken steptronic, steptronic bush
